BIKELAND > FORUMS > ZX10R ZONE.com > Thread: nitrous w/quick shifter NEW TOPIC NEW POLL POST REPLY
on1whl
posted February 26, 2005 05:01 PM
I have an 04 zx10r...I am running an akra evo2,dynojet PCIIIUSB & quick shifter,MPS fast fi box,bmc filter and a 30 shot of nitrous....I will also be getting the new dynojet ignition box when it is available. Might also install the high comp gasket and degree the cams..
I heard at a local shop that there could be a problem running the quick shifter with the nitrous??? the shifter automatically cuts the ignition so the clutchless shift engages with no power to the trans...they said if the shifter is hit while still spraying the nitrous could mess the motor up and fill the airbox full....causing god knows what problems...
He said that someone at nitrous express stated a wire w/inline fuse needs to be run to keep this from happening...he did not have the specifics...
Does anyone here know or can they find out???? Maybe some info or diagrams on the installing this or what parts are needed...
on1whl
on1whl@hotmail.com
rac4it
Bergie
posted February 27, 2005 08:48 AM
No problems using an ignition kill shifter and dry nitrous.
dynosoar
posted May 09, 2005 11:25 AM
Dynojet is not an ignition kill, its a fuel kill which is better with dry nitrous. Just don't try using it with a wet system!
ECTA Monster Mile, 2x 1000cc Production record holders on ZX-10R
www.championmotorsports.biz
  Ignore this member    Click here to visit Dynosoar's homepage.
ianred1
posted September 28, 2005 06:30 AM
well , nitirous on a zx10r , ive been told that the valve guides crack badly, moltable problems at speed shops, they change them out with brass guides! for strength!
rac4it
Bergie
posted September 28, 2005 05:02 PM
you need to change your signature you dont hold any records at maxton anymore
Hells Dark Lord
living life, and loving it.
posted September 28, 2005 05:48 PM
lol@ Bergie, aint cutting anyone any slack are ya...lmbo
0.27092385292053 seconds processing time
