blazin
posted January 30, 2005 09:51 AM
won't shift into first
I cannot get my bike to shift into first. Also it will not shift passed 2nd gear. I am trying this in the garage and and rocking the bike back and forth with it running. I was wondering if anyone had any ideas. I just put on a new rear set cause mine was broken. It is a stock rear set. Also I tried changeing the postion of the shift lever...it didn't help.
please help
thxs
junior s
posted January 30, 2005 10:00 AM
did you get the lever on the splined shaft on in the exact same spot ?
when you broke the old rearset could you have damaged the gearshift mechanism ?
Get up off your ass and ride !!
10rmotor
posted January 30, 2005 07:24 PM
You should be able to shift it into first with the engine off and just rocking it back and forth. It won't go into second unless you are moving forward.
extremelean
posted January 31, 2005 07:22 PM
Did it shift before you replaced the footrest stay and how did it get broken in the first place?
FYI
Your ZX10 has a positive neutral finder and will NOT shift into 2nd unless the rear wheel is spinning at a certain speed.
The positive neutral finder consists of 3.... 5/32" steel balls that reside half way inside 3 seperate channels cut into the Output shaft (theses channels are only long enough to allow 5th to engage 1st while at rest), and halfway inside of 3 holes drilled into 5th gear, "AT REST", these balls stop 5th gear from sliding which must slide for second gear engagement (other gears are being moved at the same time, 5th gear DOES NOT engage 2nd....sequential gearbox dont ya know).Once enough centrifugal force is exherted the balls move outward in the drilled holes releasing 5th gear, making it free to slide on the shaft.
Hopefully you understand what I just said.....I tried to make it as simple as possible but with a full explanation.
baroines
posted February 02, 2005 09:48 AM
Kawasaki's only shift first and neutral when stopped.
You've got to be moving or the engine must be running to shift second and up.
posted February 03, 2005 08:09 AM
baroines ... much clearer that the gobble-dee-gook the extremelean spewed !
wylde
posted December 28, 2005 10:51 AM
make sure that the part with the splines that slips over the shaft itself is on correct,, the shift rod when correct (isw above the shaft,,if it is flipped (under the shaft,,you will have problems,,it happened to me) hope this helped
There you go again,,NOT being aware of yourself !
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted December 28, 2005 10:51 PM
Gook is good. Gobbled or otherwise. You of all people should know that.
boman
posted December 29, 2005 12:39 PM
Edited By: boman on 29 Dec 2005 12:40
you saying fish is a gooper gobbler ??????????????
Don't hate me because I own a 10 Hate me because you cant ride it !
extremelean
posted December 29, 2005 05:52 PM
are we bringing threads back from the depths......did anyone catch the date of this thread
posted December 30, 2005 09:47 AM
So?
posted December 30, 2005 09:50 AM
quote: you saying fish is a gooper gobbler ??????????????
Apparently. Why else would he chastise XL for not swallowing?
