BIKELAND > FORUMS > ZX10R ZONE.com > Thread: blinking NEW TOPIC NEW POLL POST REPLY
blazin
posted October 22, 2004 02:16 PM
blinking
I tried using the search for the answer to this with no luck. I installed the new euro turn signals and now my flash rate is normal most of the time but goes faster on random intervals. Is this due to the euro bulbs or....
posted October 22, 2004 02:30 PM
Yep, it's the Euro bulbs. They don't draw enough current to make the US flasher work properly.
D
posted October 22, 2004 02:32 PM
Either bulb should have same flash rate at all times.
If flash rate is changing then there is prolly a loose bulb/connection somewhere.
posted October 22, 2004 02:54 PM
Regardless, the Euro bulbs are not the correct ones.
blazin
posted October 22, 2004 03:45 PM
are they replaceable with the stock bulbs from my origanale bulbs??
D
posted October 22, 2004 03:48 PM
They are for Europe(you knew this was coming).
They make the flash rate higher when combined with the US spec turn sigs.
Use whichever ones ya want - puttin the US spec bulbs in the Euro's will return the flash rate to it's previous level.
posted October 22, 2004 03:56 PM
What he said.
kz2zx
Nobody in Particular
posted October 22, 2004 04:10 PM
The euro signal housing will take an 1156 bulb, and that will cure the flashing rate.
Send your old bulbs to Redelk if he still wants 'em? Red?
blazin
posted October 22, 2004 07:13 PM
ya if red wants em he can have em
0.23283219337463 seconds processing time
