BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Dyno run this sunday NEW TOPIC NEW POLL POST REPLY
otto65
posted October 14, 2004 01:21 AM
Well people the time has come. The little blue meanie is now sporting a full Arata sytem with PC3USB. Sunday 10 am we have a appointment for a remap on a 250 with the tuning link software . I will also do a stock versus BMC street air cleaner test. No TRE ...yet. What do you think she will make????? Any pre dyno setup info?? I will definetly lube the chain. Thanks Otto
Its all part of my master plan to rule these worlds
RAC4IT
Bergie
posted October 14, 2004 04:06 AM
proper oil level, chain tension and tire pressure are important for good results on the dyno.
D
posted October 14, 2004 06:09 AM
158
psycho1122
posted October 14, 2004 06:54 AM        Edited By: psycho1122 on 14 Oct 2004 07:55
Disconnect and block off the air tube feeding the reed valves on top of the head (If you don't have block off plates) while the lamda is in the pipe. If you don't, the dyno will think your engine is leaner than it actually is.
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted October 14, 2004 07:05 AM
According to my secret inside sources at Kawasaki, a valve adjustment and throttle body synch is good for at least 12 hp
posted October 14, 2004 08:17 AM
163
k bryant
Sponsor
posted October 14, 2004 12:24 PM
Air pressure up to 35 psi. Tighten the chain. 160 would be really good on pump gas, with a map and full system, BMC. No other cheating now.... Pump gas only Well, itz only cheating if you don't tell us about it.....
Y2KZX12R
CompetitionCNC.com
posted October 14, 2004 02:43 PM
dont worry, we wont cheat.
I havent a clue what this thing is capable of making. Shit it hasnet even had the cam cover off yet.
But I'll bet it will make more power this spring. Right dave? lol
Is Rocky going?
Y2KZX12R
CompetitionCNC.com
crispin
posted October 14, 2004 05:37 PM
I have 158 on my Blue with a slip on and PC3
I say 162.5
04 ZX10-R Blue
slightly mod'd...
RadCow
posted October 14, 2004 09:01 PM        Edited By: RadCow on 15 Oct 2004 22:55
Your configuration is the one Im most curious to see a full dyno plot for.
(Arata)(BMC_Race)(PC3USB)(DJ250)
Real curious bout' the filter too.
Thanks for keeping us posted!
DB
posted October 14, 2004 11:24 PM
Question: How does the higher rear tire air pressure help the hp numbers? And about how much?
Dan
04 ZX10r (Track only)
08 Concours14
otto65
posted October 15, 2004 01:18 AM
Rad Cow, The BMC is a street version. The first run will be with the stock(new) air cleaner . Then the BMC is in and will map the bike to it. When the results are in I will attempt to post them. Jim , Rocky will have his little 954 Honda going on after me. What about the (182HP)ZX12 green meanie??? Come on same day dyno runs. Am I making you nervous?
SPROCKET
posted October 15, 2004 03:50 PM
It helps with rolling resistance. More air in the tire means less tire on the roller, which means less resistance; more HP.
AUT VINCERE AUT MORI.
Y2KZX12R
CompetitionCNC.com
posted October 17, 2004 10:00 AM        Edited By: Y2KZX12R on 17 Oct 2004 11:02
Well, I just got back from the dyno. Conditions were good so the correction factor was .99
59.81 F 29.25 baro 36% humidity
Stock air filter was first tested with the arata and a supplied dan kyle racing map. 152.83 hp 75.17 tq
BMC street filter added (right out of the box, full of oil), then several "oil suck out" runs done which did make a difference. stablized at 151.x hp 75.x tq
After the remap... 155.58 hp and 77.31 tq.
The target a/f ratio above 20% throttle was 13.0 but its mostly on average 13.4 or so.
Then the 03 954 went on. arata exhaust and k&n filter. 141.x hp
After a remap 144.x hp
I dont have much more info yet on the little honda other than 144.x hp.
Y2KZX12R
CompetitionCNC.com
RadCow
posted October 17, 2004 06:29 PM
How many miles are on that 10 these days??
crispin
posted October 18, 2004 04:02 AM
155 seems kinda low but it is all about the dyno.
Like I said I run 158.5 with a slip on, PC3, and custom mapping.
That is on a dyno that has seen most R1's will full exhaust running 161
04 ZX10-R Blue
slightly mod'd...
BIKEMIKE
posted October 19, 2004 11:13 PM
Have you thought about maybe trying the race filter??
D
posted October 20, 2004 06:59 AM
How many miles are on the bike?
These bikes seem to break in over the course of 2000+ miles.
My bike put down 156 with a bolt-on and BMC Race filter - that was just over 5hp difference as compared to the last time it had been dynoed.
First dyno was at 2200 miles and this result was at 4300 miles with the only difference being the BMC Race filter.
I'm not gonna sit here and say it was the filter though - that might have been good for 1 or so hp.
The bike dynoed at 146 at 1300 miles and 147 at 2200 miles (both runs on different DJ250's).
SP8
posted October 21, 2004 01:18 PM        Edited By: SP8 on 21 Oct 2004 14:20
Those numbers sound spot on for SAE correction. My TiForce dynoed 162 to 161 hp using STD correction. The same dyno chart showed 157.14 hp using SAE correction. That's with a Full TiForce system, custom map, and stock air filter. That also was a Dynojet 250 load control dyno using tuning link software.
otto65
posted October 23, 2004 03:36 AM
The bike has 4700 miles. SP8, Good info on Dynosolutions. Bike runs mint. I would recomend this guy to all in the area.
SP8
posted October 23, 2004 05:24 AM
No problem...... John at Dyno Solutions is way cool. I plan to check him out again after some winter mods. Your tire wear could also effect the hp numbers. To bad you didn't have a before and after exhaust pull. That really shows what your mods have done for you. I dynoed stock at 148hp SAE, and 154hp STD at FLM. I broke my bike in semi hard. I was briefly taking her up to 10,000 rpm from day one. Even the dealer I bought the bike from said ignore the break in sticker. It's important to work your rings from day one. I always varied my rpm, and hit 10,000 rpm for a short time when possible. As I got more miles, I increased the burst peak rpm. I didn't hold it open for any length of time at high rpm until 1800 miles.
dash
posted October 23, 2004 08:10 AM        Edited By: dash on 23 Oct 2004 09:18
almost identical mods for my 10 (even a blue one too)Arata, BMC, PC usb, and mapped by Chris Hill/Performance Psycle. Also dyno was a 250. Sorry, won't reveal hp numbers 'cause I'm real secretive about that right now, but we were very pleased with this simple set up (nope, valve cover not off this one either.....yet). Bike has 500 miles and is my Prostar bike. Really like seeing more of these Arata's out there. I have the only one in Prostar 1000ss and am looking for a little support from Arata for next season. Wanna see a real good pic of an Arata on a 10R? Go to Dragbike.com pics in the winners/awards page. That should make Arata proud!!!
Dash
0.22157192230225 seconds processing time
