BIKELAND > FORUMS > ZX10R ZONE.com > Thread: wide band commander NEW TOPIC NEW POLL POST REPLY
den
posted October 22, 2004 08:34 AM
wide band commander
who ever tries it ? who knows something about it ?
D
posted October 22, 2004 09:04 AM
Air/Fuel ratio meter.
NINJA12
posted October 22, 2004 11:24 AM
I have the LM-1 that doug spencer sell, Great tool!
Karl and johnnycheese were the first two with great reviews.
What do you want to know?
Instant A/F will riding.
Data logging for easy mapping.
Easy install.
I'm not a salesmen but if you like to tune and tinker this is a must have.
It's a poor mand DYNO!
SP8
posted October 22, 2004 05:10 PM
I want a Wide Band Commander. The thing that bothers me is having someone weld the sensor bung to my TiForce. I hear steel, and Ti don't like to be welded together. So a one off Ti bung will need to be made for all us non-Akra, and Micron Ti pipe owners.
den
posted October 22, 2004 06:05 PM
already ordered it, get it next week, here there's no dyno, and all supplied maps for the 10r and my 12r aren't good, so i must have this tool to tune myself my bikes, the wide band commander is not expensive.
"I have the LM-1 that doug spencer sell, Great tool!
Easy install.
It's a poor mand DYNO!"
ninja 12, is it easy to have the best A/F ratio ? what's the best for the 10r and the 12r?
BIKEMIKE
posted October 22, 2004 06:47 PM
Who did you order it from DEN?
den
posted October 22, 2004 06:55 PM
i ordered in France.
ninja12
posted October 22, 2004 07:14 PM
Best A/F ratio is a little hard to say even with a dyno. short answer ~12.2.
This tool will tell you what your A/F is at a certain tps and rpm.
example... you hit record and ride your bike just like you always do.
Stop lights, run it thru the gears, whatever, then go back a look at the
A/f map. If a squre (2% tps at 5000 rpm) was 13.5 in the a/f map then you go into the same square in the power commander map and make adjustments. Then go ride again.
If your bike misbehaves at a certin RPM, hit record and go to that RPM. no more guessing rich or learn , and at what exact RPM and TPS.
For everyday traffic you would be VERY supprised at how few squares are used.
den
posted October 22, 2004 07:26 PM
thanks for these infos. i suppose you did it. and how is your bike running now?
BIKEMIKE
posted October 22, 2004 08:16 PM
ninja12,
The LM-1 with no add on's will do that? Is it hard tp hook up?
Mike
den
posted October 23, 2004 06:03 PM
bikemike, you don't need that tool, your 10r is already tuned by Ivan.
BIKEMIKE
posted October 23, 2004 06:36 PM
I don't need the 10r either but I thought it would look cool at the dragstrip if I whipped out my laptop and plugged in. I guess I could plug into the Power Comander and just play solitare, save some money
big daddy
posted October 23, 2004 06:50 PM
Aren't these commonly referred to as Lamda sensors?
BD
BIKEMIKE
posted October 24, 2004 02:14 AM
Hey den,
When you get hooked up please report back here on how you like it. I want another toy.
Mike
ninja12
posted October 24, 2004 11:47 AM
you do need the adaptor to get tps,rpm, ETC.
It's only ~$100, which brings it in line with other units $450-500.
The base unit give a/f but has no inputs for rpm or tps.
Sorry if i mislead you.
BIKEMIKE
posted October 24, 2004 01:54 PM
No mislead,
Did you hook that up on a ZX10R?
Was it hard to access the inputs for the RPM and TPS?
Did you mount that unit on the bike, it looke a little large from some vid's I saw of it?
Thanks for the help,
Mike
den
posted October 24, 2004 05:43 PM
No mislead,
Mike
i email these questions to the french dealer and waiting for answers, sure i will let you know. I'll get mine next week
NINJA12
posted October 26, 2004 10:13 AM        Edited By: NINJA12 on 26 Oct 2004 11:27
It's a little large for bling
(approx 7" x 4" x 2"), but it's a tool.
Hook it up, tune your bike, take it off.
I have a zx12. 2 wire to battery +,-.
1 wire tps, 1 ground , and 1 (RPM) coil ground.
All 3 can be found at the ecu.
very simple one you fine the wires.
BIKEMIKE
posted October 26, 2004 10:29 AM
Thanks.
NINJA12
posted October 26, 2004 11:17 AM
Don't forget you must have a bung welded into you header!
BIKEMIKE
posted October 26, 2004 11:25 AM
It's on my Akra.
SP8
posted October 26, 2004 04:30 PM
Has anyone done this yet?
den
posted October 26, 2004 06:19 PM
sorry to reply late to your post, i agree with you. i like being able doing things by myself.
den
posted October 31, 2004 09:43 AM
GOOD! the wbc just arrived take some pics as soon as possible, great tool, it records air fuel ratio and you can modify your pc3, see that was too lean about everywhere !! i began to work on my map, and trying same time great, i can feel the difference!!
BIKEMIKE
posted October 31, 2004 10:28 AM
Great news Den, keep us posted.
0.23761105537415 seconds processing time
