KeepHerLit
posted July 12, 2004 04:43 PM
Front end shake
Anyone noticed a shake coming from the front end? I noticed mine doing it yesterday at around 50mph. Doesn't seem to affect the handling with both hands on the bars. I've got 1300 miles on it and never noticed it before. However looking back whenever I have rode it for a while I get carpal tunnel like numbness in my left palm. After a couple of days it goes away and if ride my 7 there's no sign of it, whenever I ride the 10 it comes back again so I would guess it's been like this since new.
Michael Lee
Purchase Ivy
posted July 13, 2004 08:11 PM
Have not felt anything like that on mine, maybe you need to get your dealer to check it out. could be a wheel out of balance or tire pressure? just trying to help out . . . good luck
sp500
posted July 13, 2004 10:33 PM
I've noticed this too with regard to the numbness, possibly from alot of clutch use and trying to hold onto this damn missile.
kz2zx
Nobody in Particular
posted July 14, 2004 04:42 AM
Left hand? Does the clutch cable have any free play? Bet you're getting vibration transmitted up the clutch cable...
It needs some play, too, as you climb the RPM range under power, it seems to tighten up, then loosen as you roll off the gas. Maybe something to do with the slipper clutch, dunno.
You can also try heavier bar end weights. Failing that, it may be pressure on your nerves at the pinchpoint of the wrist. I take my watch off when in my leathers or wearing my (very stiff) commuting jacket, and the pain I used to get in my left wrist (and still do, if I forget) is gone.
ASMA 47
WERA 147
www.dhowellbooks.com
jmg893
posted July 14, 2004 10:40 AM
My front end shakes above 40 mph. With hand on bars if you pay attention you know something is happening. Take your hands off the bars and the front end shimmys a very small but high speed oscillation back and forth. I'm wondering what to do myself.
Jonathan
ZX10R, FZR400
WSMC #699
posted July 14, 2004 11:06 AM
Maybe keep your hands on the bars?
jmg893
posted July 14, 2004 11:50 AM
Edited By: jmg893 on 14 Jul 2004 12:51
umm, yeah!!! Take a look at what I said again, that even with the hands on bars you can tell something is going on. I don't need to tip into turn __ at a trackday and have what could have been only a "moment" become a full-on "event" because something wasn't right in the front end. Any replies with info beyond the obvious?
Jonathan
ZX10R, FZR400
WSMC #699
posted July 14, 2004 12:09 PM
Well, I won't mention the obvious things, like checking tire pressure, balance, signs of cupping, head bearings, etc..
fattkaw
posted July 14, 2004 03:23 PM
I'd give the head bearing a little tweek!!
sasrac575
posted July 14, 2004 04:33 PM
hey guys ....
with aprox 700 miles on my 10 i too noticed some front end shake at around 40 - 50 mph . shortly after a belt in my front tire failed (dunlop 218) I brought my front rim to my dealer where they dismounted it and found belt seperation.
dunlop is sending me a new 218 which ill sell. i now run mich.pilot sports and have had no more probs....
please take the time and have the tire dimounted and checked! when mine failed i almost took out my shiney new 10....
KeepHerLit
posted July 14, 2004 06:33 PM
The dealer did a test ride today and confirmed that i'm not going crazy. He thinks the head bearings need looking at and adjusting as necessary. The mechanic who did all this seems a pretty savvy and straight up guy so hopefully he's hit the nail on the head and can fix it quick. I also hope this is causing the numbness, if not I'll check out what you guys have said. I'll let you guys now how I make out.
The dealer said this probably would not be covered under warranty because it could be preventative maintenance. This dealer did the 600 miles service and according to the manual the bearings don't need lubing until 15k miles. My feelings are this should be covered under warranty, any thoughts?
jmg893
posted July 14, 2004 07:32 PM
Re: this problem I heard loose head bearings on another site too, so I'm gonna check mine as well as the wheel balance, tire condition (pressure is fine, I check it regularly so it isn't that, neither is it cupping).
Jonathan
ZX10R, FZR400
WSMC #699
TLR2000
posted July 14, 2004 07:59 PM
I had 2 different issues with my 10R causing headshake,
First was the wheel, It was machined out of round, Warranty replaced.
Second was the 218 tire, I replaced it with a Rennsport.
The bike is so much better!!!
KeepHerLit
posted July 16, 2004 03:07 PM
It turns out the wheel is warped. I had a minor high side 15 days after I got the bike. Hit some sand then gripped again and the bike and me ended up in some guys front yard. Fortunately it was a slow left hander so there was minimal damage, upper fairing needed replacing and front brake lever. Apart from that there where a few minor scratches. The dealer is saying it must of happened then although I honestly can't see it. Either way Kawasaki said they would replace the wheel under warranty, only problem is they are now on back order.
posted July 17, 2004 01:31 AM
That's good info, thanks. This kinda reminds me of the differences between wrecking an previous generation R6 and a previous generation ZX6R when roadracing. The older gen ZX6R was heavier, but withstood crashes much better than the R6 did...
zeta xray
posted July 17, 2004 12:49 PM
quote: My front end shakes above 40 mph. With hand on bars if you pay attention you know something is happening. Take your hands off the bars and the front end shimmys a very small but high speed oscillation back and forth. I'm wondering what to do myself.
I had the exact same shake on a '98 R1, a '99 R6 and the ZX10. Replacing the front tire with something other than a Dunlop cured this problem every time. I wasn't surprised when the ZX10 did the wiggle. I was hoping the D218 would be better.
TLR2000
posted July 18, 2004 05:59 PM
quote: It turns out the wheel is warped. I had a minor high side 15 days after I got the bike. Hit some sand then gripped again and the bike and me ended up in some guys front yard. Fortunately it was a slow left hander so there was minimal damage, upper fairing needed replacing and front brake lever. Apart from that there where a few minor scratches. The dealer is saying it must of happened then although I honestly can't see it. Either way Kawasaki said they would replace the wheel under warranty, only problem is they are now on back order.
My Dealer took one off of a Display bike and had me going in less than 2 hours!
