BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Question about the exhaust mod NEW TOPIC NEW POLL POST REPLY
600rr
posted June 05, 2004 09:16 AM
Ok so im sick and tired of wating for my muzzy pipe.....been 2 mounths......anyway i took an air hammer to the cat....but i also have a power commander (running the stock bike map)....i have been getting some wicked back fires and pops.....My question is: Am i hurting the bike in anyway from the backfires....it seems to only do it on decel.....not many pops.....just a bike BOOM..and not everytime.....Thanks for the answers in advance....(i know there are some bike gods on here. so i hope 1 of them will respond with a real answer and not flame me for being ignorant).....
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted June 05, 2004 09:29 AM
I dunno what's up with mine. Did the cat mod, drilled three 1" holes in the baffle and it STOPPED popping on decel. No other mods. Makes a nice raspy noise now too. I only put a 2" hole through the center of the cat, could that explain something? It's ok to flame ME for being ignorant. I forgive myself.
TLR2000
posted June 05, 2004 01:38 PM
I'd be looking for a leak around the mid pipe connections, Decel backfire is usually caused by fresh air being sucked in around a mating surface, Just knocking out the cat. will not cause these symptoms.
marc zx-10
posted June 05, 2004 02:11 PM
i get the same pop from my bike. but i have a micron slip-on on my bike.
posted June 05, 2004 06:10 PM
That's because Microns suck
air in around the junctions.
dket
posted June 06, 2004 04:19 AM
The pop comes from a lean condition and a closed throttle . Get a PC3 and a map made for YOUR bike .
Why aren't the exhaust experts chiming in on this ?
worm~hole
posted June 06, 2004 04:34 AM        Edited By: worm~hole on 6 Jun 2004 05:34
...they have no time to read stuff like this...besides, lots of other experts here who can answer simple stuff like that...the exhaust experts are probably they're busy working 24/7 as you requested so that they can get pipes out...
who would do us harm.”
-George Orwell
CanyonCarver
posted June 06, 2004 06:46 AM        Edited By: CanyonCarver on 6 Jun 2004 07:55
The popping on decel is caused by the KLEEN system exhaust air injection. If you block them off with vacuum caps or block-off plates (cleaner) the problem will go away (or at least subside considerably).
Pic:
12RPilot
posted June 06, 2004 07:23 AM
My ZX-12 had a custom map made on a dyno and it popped when I shut the throttle from high revs. Never worried about it myself. I just wished it would have shot out some cool flames!!! That would rule!!!
NESBA #209
0.2422468662262 seconds processing time
