worm~hole
posted June 03, 2004 10:57 AM
hot rod set up
...please excuse the play on words (got yer' attention, didn't it? )...but what type of rod stock and what diameter do I need use to stick through the hollow swingarm pivot bolt to support the rear end up off the ground?...a precise fit would be optimum (trying not to to bugger up the ID), but very close will do, too....thanks!
who would do us harm.”
-George Orwell
worm~hole
posted June 03, 2004 11:26 AM
Edited By: worm~hole on 3 Jun 2004 12:27
*burp*
-George Orwell
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted June 03, 2004 11:45 AM
I used a 3/8" x 36" galvanized rod from the Home Depot. If you drill out the spot where forging the hex socket has pinched the right side, it will take a 12mm shaft. Not sure I'm ready to do that without looking at the swingarm axle a little closer. Keep those jackstands close to the frame. The 3/8 mild steel rod is strong enough if you heed that precaution.
worm~hole
posted June 03, 2004 12:09 PM
danka!
-George Orwell
Sonic10
posted June 04, 2004 09:54 AM
bita? just testing my useless knowledge.Am I correct?
worm~hole
posted June 04, 2004 10:04 AM
bitte?
-George Orwell
posted June 04, 2004 03:02 PM
Bite me
worm~hole
posted June 05, 2004 01:14 AM
nein!!!!!
-George Orwell
posted June 05, 2004 07:13 AM
K nein
worm~hole
posted June 06, 2004 01:09 AM
good one!
-George Orwell
