BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Track Day Tire Pressure??? NEW TOPIC NEW POLL POST REPLY
Deezy
posted June 04, 2004 11:23 AM
I have my first trackday tomorrow (Talladega short track) and I need to know at what PSI should my brand new Pirelli Diablo's (120-70 and 190-50)?
zeta xray
posted June 04, 2004 01:26 PM
The Pirelli tire dealer at the race track in our part of the world told me to run 2 psi higher than I ran in my Pirelli Supercorsas. I ran 30 front and rear in the Supercorsas. So that should mean 32 f/r on the Diablos.
Elsewhere on this forum someone detailed how to tell if your pressures are too high or too low. He said ideally, you should have a 20% rise in pressure between the cold and hot pressures. So if you start with 30 psi cold, you should have 36 psi hot. What he said sounded reasonable to me.
Deezy
posted June 04, 2004 01:38 PM
Thanks a lot. That eases my mind.
big daddy
posted June 06, 2004 08:01 AM
That is indeed correct Zeta.
FYI as a suggestion the front is typically 1-2lbs higher than the rear when using street/DOT race tires.
BD
0.4633891582489 seconds processing time
