posted April 12, 2004 11:59 AM
Installing a Threaded Boss for a Damper... Anyone have suggestions on fitting a threaded boss for the 10 similar to what the ZX-6RR has? I have two Ohlins dampers that are too large for across the tank (and there are no fitting kits out yet anyway), but that would work perfectly as side mounts.
The only question is how best to produce a mounting point for the frame. Obviously, welding is a possibility, but that might look crappy.
posted April 12, 2004 12:28 PM
You know, it all depends on the person doing the welding, I have partners that are pipe fitters and they say the welds on the frames look like shite comapred to the quality & specs they have to adhear to. And then you have the refinishing of the frame, paint ot polish it... Hmm?
posted April 12, 2004 05:53 PM
Edited By: extremelean on 12 Apr 2004 18:54
KHI has made a bracket that bolts on to the upper engine mount, RH side I believe.
I have pictures...will see if I can get them posted up......I also have a part #.....not a cheap part.
posted April 13, 2004 07:49 AM
Edited By: Scott_in_FL on 13 Apr 2004 08:50
XL, crazy enough, I was looking at that mount last night (on the left side though) and it appears close enough that something could be done quite easily. But, if Kawi has a part #, it may just be easier to go with their piece.
Could you shoot the part # to me? email sweires@yahoo.com
posted April 14, 2004 11:36 AM
Part # for bracket....... 11053-1241 ETA is 4/30
Akrapovic Evolution II (Titanium only) K4243-779 In stock
I though we were going to have the Carbon but I have been told we are "NOT"...sorry boyz.
I will have pictures up very soon of both carbon and titanium, and pics. of the damper bracket.
