BIKELAND > FORUMS > ZX10R ZONE.com > Thread: anyone change oil yet? NEW TOPIC NEW POLL POST REPLY
detroitdiablo
posted April 06, 2004 07:41 PM
want to change the oil in my new 10 and bought a filter, does anyone know if you have to buy a new gasket for the drain plug? never heard of that a "gasket" but it says in the manual to change the gasket in drain plug? please fil me in, and also what type of oils is anyone using? thanks
May you be in Heaven five minutes before the Devil knows your DEAD!
KZ2ZX
Nobody in Particular
posted April 06, 2004 07:54 PM
The gasket stayed on the bike when I changed mine. Get contact (or brake) cleaner and tinfoil, use the tinfoil to direct most of the oil from the filter into the drainpan. The remainder that spills onto the headers you'll clean with contact cleaner.
I'm using the Kawachem non-synthetic oil until I get 1800 miles on the bike, then switch to synthetic, most likely Mobil-1.
posted April 06, 2004 08:14 PM
Same here. I didn't have an oil filter wrench so I couldn't verify the torque on the filter. Went ahead and put a hose clamp on the filter and safety wired it so that I knew it wouldn't back off.
12RPilot
posted April 07, 2004 01:42 AM
Never heard of the tin foil idea. Ideas like that are just one more reason I lurk here.
hammerli
posted April 07, 2004 01:50 PM
Another possibility is to use a large clear plastic bag, and unscrew the filter into the bag. Then just dump the contents of the bag into the pan. Not home right now to look and see if that will work well. Even with that, the tin foil would still be necessary to shield the warm headers. I haven't changed mine yet, but normally the "gasket" is actually an aluminum or other soft metal crush washer. They can usually be reused several times. I am planning to use a non-syn. for the first change, then go to syn. at 1500 miles.
posted April 07, 2004 04:32 PM
I'll be doing my oil tomorrow.
0.22070908546448 seconds processing time
