BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: help 117 mph @ 1/8 NEW TOPIC NEW POLL POST REPLY
ninja12
posted May 15, 2003 05:29 AM
help 117 mph @ 1/8
If a stock motor 12 runs 117-118 in the 1/8 what
would you expect to run in the 1/4?
180lb rider. street ready bike.
i'm getting a best of 144mph i think it should be better.
zrxdean
posted May 15, 2003 06:13 AM
Sounds about right to me. What kind of ETs?
your car is slow
Fuck Nitrous...Got Boost?
posted May 15, 2003 06:24 AM
I pick up between 28 and 30mph on the big end on motor...so thats about right.
Do not taunt happy fun ball!
posted May 15, 2003 07:19 AM
sounds about right I run 117 and then 142 or so in the 1/4, and Im 235.
MM
ninja12
posted May 15, 2003 07:25 AM
mostly 9.55-9.75 best of 9.48 (last year)
30mph over 1/8mph is what i expected.
bike ran 147- 150 last year but my et is better now just seem the
bike is not running on the top end. never been mapped on a dyno.
best this year
rt .138
60 ' 1.581
330 4.117
1/8 6.194
mph 118.33
1000' 8.005
1/4 9.552
mph 144.27
bike has never been mapped on a dyno. can a map make that much difference?
your car is slow
posted May 15, 2003 07:58 AM
COULD make a difference
Id get a dyno run with an A/F printout personally....if the A/F ratio is all over the place...then yea..a tune would certainly help.
ninja12
posted May 15, 2003 08:50 AM
Madmike i think ~50lbs should be good for more than 2 mph.
your car is slow
posted May 15, 2003 10:47 AM
you are assuming your bike makes as much hp as his does.
Lot more factors play into your ET/MPH than simply weight.
ninja12
posted May 15, 2003 11:07 AM
You're right.
I'm based that on stock motor in decent state of tune,
bike and rider race ready.
1-2 hp will only show up with the really good riders.
ET is skill,
mph is hp if the rider don't get in the way.
your car is slow
posted May 15, 2003 11:30 AM
hehe..you think all stock motor bikes make within 1 or 2 hp of each other?
Thats a bit optimistic dont you think?
posted May 15, 2003 11:47 AM
well another factor (or many of them) would be mods, such as my bike alone weighs in at 490 now with 1-2 gallons of gas. so I may weigh more then you but we are probably close, in total weight...
BA
posted May 15, 2003 02:23 PM
......just chipping in that I also think 144mph matches your 1/8th mph pretty well for a 180lb'er.
Dont' forget though that slight gearing changes and your shift point will make that 2mph difference in 1/4 mile MPH as well. I'm not sure how much you're geared.....
Having to get out of the gas a little bit in first gear because of a slow wheelie hurts MPH just that little bit, as well.
Most of my runs are 28mph-29mph difference between 1/8th and 1/4 too.
kcadby
posted May 15, 2003 06:26 PM
That is pretty close but...I think you SHOULD be able to run closer to 147 (again)...
As BA said...your shift point and gearing can make a pretty big diff....
WORST thing you can be doing is shifting another gear "close to the finish line"!!!
Your better off hitting the rev-limiter "in the traps" than you are shifting another gear within say??? 50-feet of the finish line...
And yes...mapping can/WILL make a noticable diff....
I ALWAYS ran my best times/MPHs...right after a mapping session...
YEEE-up...John's bike has been mapped (at 100% throttle) at least 3-4 times a year since he bought it (even before I started this job)
It is...MUCH cheaper for his mapping now though...I.E....FREEE!!!
If you hadn't been 147 before...I'd say your running what "most people" run but...since you have run that fast before??? I'd be looking for a reason why... (air sucked [for your map] that day/night maybe)...
hotrodninja
posted May 16, 2003 04:17 AM
How was the air? Temp, Humidity, Barometer, Wind. I write all weather conditions in a log book, and can tell you that it can make over 5mph difference. It does seem that what your picking up from the eighth to the quarter is about right.
Be consistent, win money.
Matt Sterbator
Hiding in the bushes
posted May 17, 2003 09:17 AM
The quicker you cover the 1/4, the less time the bike has to accelerate. So while you may get a better ET, your MPH won't be as much because you didn't have as much time to accelerate. Notice that sometimes the ET gets better, but the trap speed doesn't ?
zxlnt
posted May 18, 2003 06:50 PM
But what about theory. The faster u acellerate on the short end of the track give you more room to accellarate on the big end of the track.. ??? Ur going quicker in less distance which gives ur more distance to gain speed down the other end. Yes, no, maybe,.....
your car is slow
posted May 18, 2003 09:16 PM
Exactly the opposite man
Quicker you accellerate...the more track you eat up because you are traveling at a higher velocity.
ZXALAN
posted May 20, 2003 11:52 AM
YOuR Car is slow, how quick does your bike run? whats your setup? just curious.
your car is slow
posted May 20, 2003 12:37 PM        Edited By: your car is slow on 20 May 2003 13:39
It doesnt
Stock motor.....stock wheelbase...bt010 tire..and I weigh about 240lbs.
Dry kit...46 jet...4.5deg total timing retard...custom PC3 map ive played with over the past year or so.
9.87@151 is my best(and only) time down the track on spray. (that was with a 40 jet I believe)
They dont let you run more than once at Gville without a license if you make a 9.99 or better pass.
ZXALAN
posted May 20, 2003 04:07 PM
AH Bummer, 151mph is damn good for 240lbs!
your car is slow
posted May 20, 2003 05:17 PM
I was happy with it...I just get disappointed that I cant make more than one run (you always get faster and faster the more you run) without getting thrown off the track.
The bike is so rich on motor....it is down to about 160hp (made a max of 175 before I started richening up the map on spray). My last trip to gville I could only run 10.20@136 with the nitrous map (and no nitrous).
Im probably going to wind up getting a Yoshbox for the dual map options and figure out some way to mount the toggle switch so I can change it at will
zxlnt
posted May 20, 2003 06:08 PM
YCIS if u do decide to get the EMS I have a NIB accessory hub for ya. Map switch mounts on handlebar..
BA
posted May 20, 2003 06:37 PM        Edited By: BA on 20 May 2003 19:42
I'd love to see someone use a PDA running Windows or something, and with a serial link, and use that to load a new map into the PCIIIR. Gotta be cheaper than the Yosh, but if I had any money, I certainly wouldn't mind having one.
your car is slow
posted May 20, 2003 08:20 PM
Ive looked into that option...however from what ive read..you cannot do any adjustments from a PDA. You can only upload and download maps. (and hell you might not even be able to upload maps) I just remember reading the information and going "god this is worthless to me".
I wanna switch dammit
Perhaps a PC4 will come out that has the Yosh functionality.
ninja12
posted May 20, 2003 08:57 PM
If you had 2 good maps, 1 for normal and 1 for nos, why would you need to adjust the map at the track?
It would not be as nice as a switch but the same result.
0.21729207038879 seconds processing time
