Bossman69
posted May 20, 2003 12:11 AM
MTC multi lockup
What fibers and steels should is use? stock or muzzy's?
8.99 @ 162 02 zx12 Gotta Love NOS
harryzx-12
posted May 20, 2003 02:30 AM
Muzzy uses oem. So oem is the answer( 2.mm steels)
Cowboy
posted May 20, 2003 06:18 AM
Whichever you want just get the stack height on the high side and then istall so you know if your going to be ok or not.MTC is sending me a longer puller rod because to get the right angle between the actuating arm and clutch cable i have to run a 2.283 stack height and that leaves my clearance btween lockup arms and pressure plate at a real tight .075.
Bossman69
posted May 20, 2003 05:27 PM
The time zone is Hawaii and work is killing me. I have to wait a day to call MTC. Any way should the puller arm spin free inside the presure plate and move around alot?
Cowboy
posted May 20, 2003 10:19 PM
yes but define alot.Did you put the little roller bearing washer and the flat washer back together correctly?
Bossman69
posted May 20, 2003 10:39 PM
I guess not I put the 1 washer then the roller and then the other washer but when I tighten the lock up on the puller arm will not spin at all. So I took 1 of the washers off the roller and now it spins but the clutch will not engauge
AnotherRedHead
posted May 21, 2003 05:21 AM
scary
Cowboy
posted May 21, 2003 06:24 AM
you have something wrong there
kcadby
posted May 21, 2003 09:49 AM
The stock puller only has one washer...did the lock-up come with two???
Bossman69
posted May 21, 2003 12:39 PM
MTC said the second washer was if the stack hieght was tall and yes mine came with 2 washers.
Cowboy
posted May 21, 2003 02:19 PM
you should not need the second washer.If you want ,e-maim me and i'll give you my phone #.
Bossman69
posted May 21, 2003 02:47 PM
You have mail
Bossman69
posted May 22, 2003 10:27 PM
Who has an 02 with the multi lock up?
