BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Anyone drag racing with a B1 or B2 model NEW TOPIC NEW POLL POST REPLY
ninjamissile
posted April 22, 2003 07:07 AM
Got my eye on B2 model 12. Wanted to know if anyone on this board races with one. If so what sort of times are you achieving with just a pipe and a arm. I know that my full Ackro system off my A1 will fit straight on but what about my arm and other stuff like my Bear Stacks,Muzzy clutch and my Schnitz dry kit. Also what will I need to de-restrict one of these models.
Cheers
Ninja Missile
your car is slow
Fuck Nitrous...Got Boost?
posted April 22, 2003 07:46 AM
Dunno about the pipe..it would probably touch the fairing...but it will bolt on to the head
The dry kit has no knowledge of what kinda bike its on
Dunno about the stacks or clutch.....although If I had to guess...I dont think the throttle body boots have changed.
Do not taunt happy fun ball!
kawachan
posted April 22, 2003 10:40 AM
Stacks will work for sure. Clutch should too!! Arm??
RED NINJAS RULE!!
posted April 23, 2003 11:23 AM
The swingarm is different, I dont know anyone that tried to put a A1 swingarm on a B1...The Akra pipe is the same for all 12s...Stacks will fit...The B1 clutch hub will fit on the A1, which means the clutch is the same...You dont need to de-restrict the B1 for DragRacing, unless you have a Pro-Mod/ProStock ZX12!!!
The B1/B2 is alot smoother than the A1/A2!!!
0.2207670211792 seconds processing time
