BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: zx14 NEW TOPIC NEW POLL POST REPLY
mighty mike
posted August 24, 2011 02:53 PM
zx14
does anyone know a great and dependable mechanic for a zx14 in GA. ? I have a dryshot nitrous system that uses the same bottle for the power and air shifter, but after 1 run the shifter usually doesnt seem to have enough pressure to shift . I think the pressure can be turned up for the shifter or maybe need to get a seperate bottle put somewhere.
wrongway
posted August 24, 2011 03:07 PM
the air shifter only needs 120 psi ... the nitrous bottle would have to be empty for that not to work. what size bottle and nitrous shot are you using ?
Roy
posted August 24, 2011 03:37 PM        Edited By: Shane661 on 24 Aug 2011 23:38
I have seen solenoids malfunction due to TOO MUCH pressure. I am not sure what your shifter solenoid is rated for, but they are typically not the same as nitrous solenoids. I believe you need a dual regulator for such a setup.
ZRXDean
posted August 24, 2011 04:37 PM
Might also be your transmission - does it work on the 1-2 shift, but not the 2-3 or higher?
Brain Livengood in Lawrenceville, Livengood Motorsports, is a good engine builder & tuner.
0.23161220550537 seconds processing time
