BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: zx12 crank swap? NEW TOPIC NEW POLL POST REPLY
krexken
posted August 20, 2011 08:50 AM
zx12 crank swap?
Hey, yall. Friend has an 00 that needs a crank but haven't been able to locate anything. Found some 02 cranks but I'm not sure if it'll work. I'm pretty sure the flywheels are different but was hoping I could use the same stator since I don't have any of the later model stators laying around. ?
NINJA12
posted August 20, 2011 11:13 PM
it will work
posted August 21, 2011 12:18 PM        Edited By: KZScott on 21 Aug 2011 20:18
its different but it will work. i finished an 02 cases, 01 crank build recently for my bike and just need to get the stand alone figured out before i fire it up.
krexken
posted August 22, 2011 07:58 PM
Cool. Thanks, guys. Stand alone?
posted August 23, 2011 05:49 PM
ecu
krexken
posted August 23, 2011 06:48 PM
Ahh. Any opinions on 1270 vs. 1287 piston kits? Gonna build a stroker. May go with APE's 139something kit. Not gonna be a daily driver. Probably going with 4.6 stroke but I'm open for suggestions. Definitely new or Carillo rods, ported head, cams.
NINJA12
posted August 24, 2011 12:06 PM
1287 Good strong motor engine, not the best for spray for head gasket reasons.
1270 can't go wrong, very solid.
Stroke either.
posted August 25, 2011 01:12 PM
you can spray the 1287, but I wouldnt go promod huge with it...
when the block is done ask for the bottom of the bore to not be chamfered like they usually do
krexken
posted August 25, 2011 06:51 PM
More drama. Nother 00 12 has a spun main bearing so it needs cases. Are all year cases interchangeable? Found an 02 for a decent price that I think I can split up for 2 00s.
Does the chamfer weaken the block? Saw your post on drilling the later model head. Good to know.
NINJA12
posted August 26, 2011 06:22 AM        Edited By: NINJA12 on 26 Aug 2011 14:22
02 has better cases IMO.
posted August 26, 2011 01:18 PM
yes. 02 has a bigger oil pump. no issues with trans ect
just better skirt support. you pull the pistons out of the bore so much with the stroker
NINJA12
posted August 30, 2011 07:23 AM
Be prepared you MAY need 24v starting if you go 1287 or larger.
some people get away with a bigger battery , but don't count on it.
0.30086994171143 seconds processing time
