BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: rear shock help NEW TOPIC NEW POLL POST REPLY
bkrfstmn
posted February 11, 2003 05:23 AM
rear shock help
ok all you drag race fans whats the best way to set up the rear shock for good consistant launches. I weigh about 210 when dressed.
cowboy
posted February 11, 2003 08:09 AM
Stock wheelbase,stock motor???
bkrfstmn
posted February 11, 2003 08:55 AM
ya, all stock but will slam this year, went 1.62 lowered 1 in, is geared 17/50
zrxdean
posted February 11, 2003 09:36 AM
The general take is soft compression and hard rebound damping, but I guess you'll need to get the stock shock revalved for it to respond to adjustments. Or you can pony up the cash for a Fox, Penske, Ohlins shock. I had Works Performance set up a pair of shocks for strip duty, very reasonable.
bkrfstmn
posted February 11, 2003 12:22 PM
if i run hard rebound will that make the headshakes worse?
zrxdean
posted February 11, 2003 01:24 PM
What most people are concerned with is the launch, where you want to absorb the weight transfer without lifting the front wheel, and hold it, instead of 'pogoing' back on the front tire, upsetting the chassis and losing traction. If headshakes are a problem, maybe get a damper.
cowboy
posted February 11, 2003 02:16 PM
Exactly what dean said and NLR does revalves for $200
bkrfstmn
posted February 11, 2003 04:46 PM
that makes sense, thanks guys
0.23206210136414 seconds processing time
