tonytee
posted July 31, 2010 02:04 AM
platinum 4 plugs or iridium
i got a friend thats says he can cross referance me some of those high end automotive plugs.who got electrocuted enough 2 help me.im sure someone tried.im sure it wouldnt hurt the engine as long as its the same lenghth.whats so good about iridium plugs anyways besides there so expensive.and should i bump up the heat 4 my bike
2000redrocket
posted July 31, 2010 05:27 AM
all i can say is i replaced the real bad 150,000mi plugs on the saturn i got and it did not really run better. if you are not going to put 40,000 mi on them before changing them i would try autolites. i think the iridium is a hard plug that will not erode fast.
i could be wrong but if you are going to commit to replacing the plugs from time to time or look and regap???
CraigChrist
BAWLS
posted July 31, 2010 11:10 AM
i know quite a few people who have changed their plugs with anywhere from 3-10k miles and picked up good mph at the track.
60ft-------1.42
1/8th------5.97
mph-------119
LeonidasZX14
posted August 01, 2010 04:13 AM
Iridium plugs are designed to last longer than platinum. That is how car mfgs can go 100k miles without a tune up. I remember back in the day plugs would only last 30k miles.
09' ZX14
1badzx12r
posted August 01, 2010 06:31 AM
Edited By: 1badzx12r on 1 Aug 2010 14:32
what i read about iridiums was they handle spark on high compression motors better .. may been a bullshit read from the plug manufacturer but thats what i read ..
posted August 02, 2010 07:51 AM
I use CR10EK
woppi
posted August 02, 2010 10:02 AM
quote: I use CR10EK
me to !
ngk cr 10ek !
1st TFA Member / Austria !
2000 Limited ZX12R NOS
LAB3
posted August 02, 2010 11:29 AM
Edited By: LAB3 on 2 Aug 2010 19:29
quote: I use CR10EK
me to !
ngk cr 10ek !
I have not changed my plugs only 9,000 miles Service Manual NGK CR9EIA-9
2007 ZX-14?? Why the different plug??
Louis
Edit you have ZX-12...duh my bad
posted August 02, 2010 12:52 PM
stock for a 12 is cr9ekpa. my 12 is not stock
