tonytee
posted July 31, 2010 01:57 AM
the little things that add power
im tryin 2 build THE BEST drag bike i could.i got all the regular stuff pipe airfilter u know.my question is the little nick nacks that u do 2 fine tune your bike the little secrets a real engine builder has.please dont tell me 2 greese the axels.thats my thing i tell everybody when i fly by them.i removed the choke flaps and rod i also removed the exhaust valve 2.im gonna get some better plugs 2 but thats another question.im about 2 tear into the motor soon so anybody got a good setup 4 that.air box mods,electrical,suspension,whatever
04 suzuki gsxr 1000
pc3
yoshi full trs exhaust
k and n airfilter
ivans performance chip
lowered
9 inch streach
tonytee
posted July 31, 2010 07:09 PM
guess its really a secret
NOX
PMRA / TMRC Super Street 4022
posted July 31, 2010 08:09 PM
Good oil.
Amsoil Dominator 5w20
oxygenated fuel.....
good overall chassis prep.....,
good shock.
badass clutch set up.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
LeonidasZX14
posted August 01, 2010 04:08 AM
quote: guess its really a secret
I don't think that its really a secret it's just that I can't read what you wrote. Try asking specific questions and you might get better answers.
09' ZX14
aliveagain
posted August 01, 2010 04:23 AM
The best dragbike is stock. It has consistency and reliability. The rider has the make or breaking of times. I have a 1426 and I am lucky to break into the nines. I suck at it but I only go for fun. If you knew which class you were going to run would be very helpful. If it is only bracket racing then quickness doesn't count. And if you want to go faster then it is only a matter of a dry shot.
1badzx12r
posted August 01, 2010 06:37 AM
Edited By: 1badzx12r on 1 Aug 2010 14:43
good oil or is that because they give it to you ..i meant sponsor you .
for us poor folks rotella 15w 40 ..
To the OP he whomever spends the most money and is skinnest is usually the fastest guy or gal .. BUT gearing is cheapest E.T for your bike go for a 3 to 1 ratio like 15/ 45
posted August 01, 2010 08:18 AM
Edited By: Shane661 on 1 Aug 2010 17:29
Learn to ride it better. That is where your ET is.
CraigChrist
BAWLS
posted August 01, 2010 08:14 PM
+1
60ft-------1.42
1/8th------5.97
mph-------119
posted August 02, 2010 07:08 AM
all the power in the world is nothing without control.
I use Motul 300v now and have had great luck with RP
AcadianaZX
Advertiser
posted August 02, 2010 12:51 PM
Oh hell. Jealous!
blueshark
posted August 02, 2010 01:41 PM
Practice will do more for you than anything you can buy. I've seen lots of guys spend a ton of money on motor work or turbo and not run good numbers because they never learned to really ride.
almost_les
posted August 02, 2010 06:57 PM
Edited By: almost_les on 3 Aug 2010 02:58
who cares how much power it makes, what matters is how you put the power down (clutch, shock, chassis)
oh, and a datalogger, wego 3 is the best bang for the buck if you got a PCIIIUSB
or get lazy and throw a slider in it and buy an airshifter cyliner, solenoid, fittings, and lines from an industrial parts supply store, hook one wire up to a 12v switched signal, like the tail light, and then wire to other to one of the universal outputs on a dynojet multifunction hub set up to acticvate with 90% throttle and rpms just far enough below redline so that you don't hit the rev limiter on the 1-2 shift. also, use the dynojet quickshifter set at 65ms kill time. all you have to do crack open the throttle and keep it pinned.
Ozonkiller
posted August 03, 2010 10:07 PM
And none of this "I got a map off of the internet" crap. Get it tuned by somebody who really knows what they're doing.
