BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: ZX12 rods NEW TOPIC NEW POLL POST REPLY
Mikkel
posted July 23, 2010 06:13 AM
ZX12 rods
My rod big ends are out of round by 0.02-0.03 mm / 0.0007-0.001". Is it necessary to resize them? From what I read it is ok to reuse the bolts 2-3 times, is that right? This will be the 2. torque. I know I must replace the bolts/nuts if I have the rods resized. The oem Kawasaki main/rod bearings and other parts are quite expensive where I live, is there a cheaper place to get them from?
Stuart Racing
N.H.R.A . Dragracing.
posted July 23, 2010 06:39 AM
I bought my rod/main bearings from Ron Ayers.com About $190.00 for a complete set.....
Mikkel
posted July 23, 2010 06:41 AM
ZX12 rods
Thanks, I will check that out!
posted July 23, 2010 05:39 PM
I personally would not reuse the bolts. cheep insurance for new ones...
Ozonkiller
posted July 24, 2010 04:35 PM
A friend of mine is a long time Kawasaki guy (used to own a dealership) and when I inquired about reusing the rod bolts in my 14 he was adament that I buy new ones. He used several examples of ZX12's rod bolts failing
My 2 cents
Tom
Y2KZX12R
CompetitionCNC.com
posted July 24, 2010 07:29 PM
If you keep a record of the rod bolt stretch each time you torque the bolts you van reuse them. If they stretch more to get the proper yield (stretch) then the bolt is going soft and must be replaced.
When you replace the bolts you need to resize the rods or at least have then checked for roundness on the big end.
These bike rods are known for going egg shaped. When this happens you will have good oil clearance but not enough clearance on the sides and you will spin a bearing when the crank and rods get hot.
To measure the stretch you need a stretch gauge and you must dimple drill the rod bolts.
Y2KZX12R
CompetitionCNC.com
0.25360202789307 seconds processing time
