BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Which wire to ground to read codes on 05 12? NEW TOPIC NEW POLL POST REPLY
krexken
posted April 07, 2010 08:44 PM
There's a lone orange wire in the tail of this bike that I'm thinking is the one you ground to read the codes but I'm not positive and don't want to damage anything. This bike runs crappy and the FI light is lit. Any help appreciated.
krexken
posted April 09, 2010 01:43 PM
Okay. Anybody with an 05 manual can tell me what 3 long, 2 short flashes indicates? That code doesn't exist for the earlier models.
Texas12R
posted April 09, 2010 09:18 PM        Edited By: Texas12R on 10 Apr 2010 05:21
11 Throttle sensor (ZX1200-B1/B2), main throttle sensor
(ZX1200-B3), malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or
short
13 Inlet air temperature sensor malfunction, wiring open
or short
14 Water temperature sensor malfunction, wiring open or
short
15 Atmospheric pressure sensor malfunction, wiring open
or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or
short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor, malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
41 Injector #1 malfunction, wiring open or short
42 Injector #2 malfunction, wiring open or short
43 Injector #3 malfunction, wiring open or short
44 Injector #4 malfunction, wiring open or short
45 Fuel pump relay wiring open
46 Fuel pump relay stuck ON
51 Ignition coil #1 malfunction, wiring open or short
52 Ignition coil #2 malfunction, wiring open or short
53 Ignition coil #3 malfunction, wiring open or short
54 Ignition coil #4 malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
0.21847701072693 seconds processing time
