BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: hyperpro rear spring NEW TOPIC NEW POLL POST REPLY
posted December 29, 2009 09:57 AM
anyone have info on a rear spring for a 12 made by hyperpro? it has 644 on it. (its purple with black letters/numbers if that makes any diff)
tcchin
posted December 29, 2009 01:51 PM
644 sounds like the rate in lbf/in, which is equivalent to about 11.5 kg/mm (stock rate is 11.0 kg/mm). Hyperpro should be able to get you whatever rate you want, based on spring ID and length. If not, I've had good luck with Eibach and of course Ohlins.
posted December 29, 2009 02:14 PM
thx, so its a heavier spring. thx for confirming. its going on my extended bike so should work well. its on a revalved shock I got in the mail today
0.20928597450256 seconds processing time
