BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: fuel cell NEW TOPIC NEW POLL POST REPLY
posted December 16, 2009 11:36 PM
fuel cell
like I mentioned in the headlights thread, Im putting a custom fuel cell in the battery compartment. Im also upgrading the NOS fuel pump to a Holley Blue with a regulator. this is what i have so far (the bubba brass fittings may get replaced if funding allows)
Im going to take it to my tig guy (really wish I had a tig, Santa you reading this??) to get it spotted, then Ill take off the tabs/rivits and get it finished.
posted December 17, 2009 01:55 AM
man o' man Scott you are always fabbing something new!
Better not let you-know-who see those brass fittings or you'll be taking a trip to the woodshed for a spanking!!!
NOX
PMRA / TMRC Super Street 4022
posted December 17, 2009 07:23 AM
There we go.
Scott breakin out the cardboard again. You go boy!
I will have pics of a new subframe soon.
Tiger tails suck, and screw stuff up, no room for chassis squat.......
More to come. Welding sunday.
Back to carboard fabbing with the master...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
aliveagain
posted December 17, 2009 08:52 AM
I would put one of those factory parts stickers on the fuel cell just to throw off the curious.
posted December 17, 2009 10:47 AM
cardboard= easy to work with
5/16 SS lines without a tubing bender= PITA
the tank allmost didnt go in, I had to clearance it a bit. lost a few of the side "nubs" of the checker plate, and took off the sharp edge on the frame. tip for bending 1/8 aluminum, v groove the back with a zip cut blade. this way it bends where you tell it to. it lead to a few cracks, so ill get every bend tigged to make sure its leak proof. kinda sucks that the best looking part will only be visable when i need to top up C16
bubba brass fittings may just get painted black
posted March 10, 2010 08:03 PM        Edited By: KZScott on 11 Mar 2010 04:06
as this project has progressed i decided to ditch the ss hard lines for fuel injection hose just incase there might be vibration issues. only problem I ran into was the tank is about 1/4 in too long, meaning i cant use the -16 cap, but rather a "low pro" steel jic cap i borrowed from dads stash of hydraulic fittings.... waiting on some more fittings(monday) and then its basically just wiring.
gotta give credit to Pierre for the excellent tig welding
Texas12R
posted March 12, 2010 03:26 AM
Great job Scott!
Thanks for taking time to inspire us !
What's are you planing next?
2000redrocket
posted March 12, 2010 02:24 PM
scott the nhra rule book says a limit of rubber fuel line total length. something like 10 to 12"
and the amount of fuel you need is no ware near the holly blue pump. for space put the holley street pump on and no regulater will be needed. that pump is still over 100gph.plenty for a wet shot. more like plenty for a lot of wet shots. sup to you.
i know what you can do with the race pump. lol .
just remember the 90deg cast fittings on there are counter productive to flow.
a street pump will still work with those fittings though.
posted March 12, 2010 02:52 PM
thanks, next up for fab work will be a tubbed undertail to get max wheel travel, Im going to drag the nuckle before the tire thinks about touching the tail. im waiting on parts/ pay checks first. I sent my stock swingarm to TCC as the one I have on the bike is limiting me to about 67 in wb I want to try 69-70 with the new shinko drag radial. next friday ill be ordering a 12 over tail. anyone want a 6 over tail with a cf step drag seat and 6-12 over arm?
Im not sure how long the factory rubber lines are, but im adding less than 5 feet for the wet kit. these lines are a lot better than the oem lines. rated at 250 psi
yeah, the big ass holley blue is over kill, but i dont want to run a non regulated pump(this one was free too). I dont like the 90s either, but they are greatly over sized, i dont think flow or volume will be a problem.... even if i doubled the jet sizes lol
2000redrocket
posted March 12, 2010 03:01 PM
the street pump is internally regulated no need for a regulator.
posted March 12, 2010 03:07 PM
I want to be able to play with pressure to fine tune afr.
2000redrocket
posted March 12, 2010 03:31 PM
cool. how big of a wet shot are you planning on rearending your bike with?
posted March 12, 2010 04:00 PM
80hp min....maybe more depending on egt and how close to my et goals i get
2000redrocket
posted March 12, 2010 04:07 PM
hold on.
0.21759080886841 seconds processing time
