BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Will a GPZ 1100 engine fit a 73-81, 900-1000 frame? [Z1,KZ,LTD FRAMES] NEW TOPIC NEW POLL POST REPLY
freddie900
zx 14 2007
posted November 13, 2009 07:58 PM
posted November 13, 2009 08:14 PM
if no one can answer this for you... these guys can!
http://www.klemmeperformance.com ask for Tom...
Johnnycheese
posted November 14, 2009 04:45 AM
yes but it is not fall in
posted November 14, 2009 06:24 AM
its just in need of slightly different front mounts isnt it?
Stuart Racing
N.H.R.A . Dragracing.
posted November 14, 2009 11:10 AM
Like JC says it`s won`t just set in the fram....I think like 2 mounts might be close and the front mounts are a rubber mount type of deal......I tried putting one in my KZ frame once, but it was a pain for me seeing as I might have to make motor change`s and most of my stuff was KZ.....As long as you can line up the sprockets good, 4 mount s should work ......KZ`s are overkill on the motor mounts.... They have like 7 motor mounts I think....I always drilled and tapped my case mount holes 1/2" x 13 with grade 8 bolts....
Good luck with it.....
Kaw Man
posted November 15, 2009 07:44 AM
I have 82' GPZ1100 that I am tring to sale.
  Ignore this member    Click here to send Kaw Man an AIM message.
SteddyTeddy
posted November 16, 2009 02:39 PM
If you have a welder, anything can be made to fit.
2000redrocket
posted November 16, 2009 05:37 PM
just do the mod to put the gpz head on the kz. i think the block may fit also the wrist pins are larger on the gpz. the gpz is a better robust engine though.
0.24357199668884 seconds processing time
