BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Throttle Position Sensor ??? NEW TOPIC NEW POLL POST REPLY
WRECKSHOP
posted June 30, 2009 11:44 AM
How do you set the throttle position sensor on a 2006-2007 ZX-10R ?? What is the voltage and resistance parameters ?? Calling on Entropy, Y2KZX12, Mr. Meyer,TCCHIN or anyone that has the know how or info because my bike is running like crap and i suspect it to be the TPS !!! Please Help !!!!!!
ZRXDean
posted June 30, 2009 12:01 PM
Is it in the manual? I have one at home.
tcchin
posted June 30, 2009 02:19 PM
Suzukis use the instrument panel display and dealer mode to set the TPS. The service manual also lists 1.1V and 1.1Kohm closed, 4.3V and 4.3Kohm open. I doubt these numbers or procedures will be particularly applicable to your bike, but you could try.
11UTE
posted June 30, 2009 06:24 PM
from 04 manual ○The throttle sensor is operating correctly if the following
voltages are obtained:
• 0.66 VDC (or slightly higher) with the throttle at the idle
position.
• 4.62 VDC (or slightly lower) with the throttle at the fully
open
Y2KZX12R
CompetitionCNC.com
posted June 30, 2009 06:56 PM
I dunno. I dont have a manual for that one.
Maybe someone can post the pages....
Y2KZX12R
CompetitionCNC.com
ZRXDean
posted July 01, 2009 04:56 AM
06-07 shop manual hosted on this thread;
http://www.zx-10r.net/forum/showthread.php?t=59403
whitehendrix
fails!
posted July 01, 2009 09:49 PM
every bike is different. some use a 5V signal and the throttle plate 100% closed to initialize rthe base TPS signal. some just call a resistance between two of the three wires and ask you to do some math to get a target resistance based on the resistance as a whole. (like the CRF 450) i dont have an answer for you, (sorry) but just wanted to point out that i's absolutely positively gotta be bike specific, otherwise the tps initialization will be incorrect.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
WRECKSHOP
posted July 04, 2009 09:49 AM        Edited By: WRECKSHOP on 4 Jul 2009 17:54
Got it fixed.....Throttle position sensor was off and we also advanced it some to richen it up a bit do to the throttle body modifications !!! FYI- We only advanced it a little bit, so dont get carried away with it if you all try this !!! Throttle response is silky smooth and very aggressive and sharp....Throttle body's been bored from 43mm to 46mm and top secondary rod removed and holes expoxied in and the throttle bores slightly polished and blended.....should be good for 5-7 horsepower !!!! HOPEFULLY ........I also got a spare set of 06-07 ZX-10R throttle bodies w/injectors if anyone wants them $125 excluding shipping !!!
whitehendrix
fails!
posted July 05, 2009 07:10 PM
aww man.. this is what i wanted for my turblow motor!! always when i don't have money
damn damn damn.
0.29964709281921 seconds processing time
