BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: ouch. its coming apart i guess NEW TOPIC NEW POLL POST REPLY
posted June 03, 2009 02:08 PM
dads motor started back firing a bit in the return lane. nothing major, drove thru pits, loaded on trailer. no oil light. hmm fouled plugs? nope not that lucky
did the rod bearings start to go?
posted June 03, 2009 05:43 PM
holy shit yes the #4 rod bearings are toast . oil pan was full of gold chunks(forgot to get a pic before we put it back on for a base on the stand). piston tagged the head on the quench pads. missed the valves at least, the valve marks are from another motor build(bought used pistons).
now the suprise. i think it was caused by sucking clutch material.... how did it get thru the filter though?...
we broke the skinny fiber... WTF?
posted June 03, 2009 06:07 PM
It doesn't get to the filter, it clogs the pick-up. But we need to see more before we make that determination.
TRNorBRN6001
posted June 03, 2009 06:23 PM
Ouch, I really hope the crank survived.
TFA 200MPH CLUB MEMBER!
osti33
posted June 03, 2009 08:24 PM
Looks like the piston tagged the plug pretty good too. Yikes. That's a bummer Scott.
posted June 03, 2009 09:25 PM
plugged pickup, lost pressure, grabbed brg, banged up piston?
sorry for your luck.
posted June 04, 2009 06:35 AM
KZ,
sorry to see yr problems; have you looked at the pickup screen yet?
I lost a motor when i was dragracing due to a clogged pickscreen so i double-damn sure know it can happen.
ZRXDean
posted June 04, 2009 07:42 AM
You might get off easy. Polish the crank, new bearings and hopefully you're good to go.
posted June 04, 2009 07:44 AM
Wow, thats a big suprise...Broken clutch plates in a ZX12???...Whats the world coming to, have a small broken fiber when u open the ZX12 clutch cover ...lol
I guess you dont have a lockup???
I and my buddies break clutch plates all the time, and our motors, oil pick ups are still clean!!!
Im sure the friction broke due to the excesive heat built up by your motor condition or during the burnout or dragging the clutch too much or making back to back passes or using the clutch while shifting or the clutch is out of spec or its was real hot and humid out or you had the bike running too much or maybe its just because the 12 clutch plates are too small and dont get enough oil to them???
Sorry KZ, just bustin chops...lol
It sucks the bearings went...what year is your Dad's 12???
posted June 04, 2009 07:46 AM        Edited By: Shane661 on 4 Jun 2009 15:49
Scott, you should have gotten 900 passes out of that clutch.
I'm interested to see the pics of the pickup. I suspect the clutch destruction and oiling issue will go hand in hand...
Even if the pickup is not blocked, it could have just sucked some pieces up that covered the intake momentarily...
posted June 04, 2009 11:58 AM
pick up had some pieces but was not plugged. Shane you may be right on the momentary plugged idea.
its a 2000, clutch was not out of spec, not used for shifting, it has a modified hub and puller for lots of oil, the plates were by no means dry, but the mtc lock up setting was way off(slipping way too much see wknd results thread). i didnt get a chance to talk to nox after making a bunch of changes over the winter. (gearing, weight, motor ect ect.) he also hotlapped it a bit....so too much slip and back to back runs = broken skinny fiber i guess.
Stuart Racing
N.H.R.A . Dragracing.
posted June 04, 2009 03:20 PM
My 02 has never had the oil pan off, and 100`s of lockup pass`s and 3 or 4 clutch`s....I can just imagine what my pickup looks like....But I change the oil way too much....
posted June 04, 2009 03:40 PM
Stuart, The 2002,3,4,5 have better oiling channels throughtout the motor...
KZ, what you mentioned would definitely due the clutch in...heat & humidity, slipping, hot lap, low tire pressure = excessive heat...
Now you know what I and my buddies have been telling you and Nox...
Wish I had the $$$ for a 14, then i wouldnt have to worry about the clutch half as much as...But then the 14 clutch has different issues, its always something...lol...Maybe the next ZX after the 14, will have a perfect long lasting trouble free clutch...lol
NOX
PMRA / TMRC Super Street 4022
posted June 04, 2009 03:44 PM
Wow, damn scott, getting good at getting rid of that lever eh.......
what did the hub look like?
From the looks of the fibers, I would say that was not the cause.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NOX
posted June 04, 2009 03:47 PM
Scott, why did you not call me????????? DAMN
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted June 04, 2009 03:48 PM
Please tell me you were using the anti chatter rings......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted June 04, 2009 03:55 PM
Well, I can see the lines on the steel from the rings......
Looks like the plates or steels got cocked, look at how it broke, right on the edge of the tab......., it appears that it was not sliding smoothly........
Show a pic of the hub.
AND BTW, I have hot lapped mine and ever broke a fiber. Only time I broke a fiber, was trying to get smart and run without the rings. Made 5 passes and broke the first outer fiber. put em back in, never broke another........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted June 04, 2009 04:00 PM
And btw crotch rocket, I never said that a lock up would fix breaking fibers, that is caused by another issue..........
It just seems odd to me, that i have done 1.32 short times at NHRA events with a 7 inch slick, and never broke them, so something you guys are doing is off, I don't care what sarcasm you or your buddy john say here on the internet.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted June 04, 2009 05:50 PM
you going to be around sat Nox? Ill be in the shop in the afternoon wrenching and can call you then
yes we were running the anti chatter rings. ill email you what the setup was, and ill get a pic of the hub on sat.
BrooklynNYZX12
posted June 04, 2009 06:09 PM
Nox,I use the same clutch set up as Ricks but I have never broken a fiber nor have I come close to a 60' like a real good drag racer,do you think the absence of the chatter rings may cause the fibers to break?I'm curious as to what would cause the fibers to snap like that.
Orient Express Top Street Bike Winner 8-4-07
posted June 04, 2009 06:40 PM
I seen and talked to HUNDREDS of ZX-12 clutches and their owners, stock, modified, and lock up, and I never saw a broken fiber.
NOX
posted June 05, 2009 05:27 AM
Yeah, just give me a call.......
I have a dance recital for my daughter mid afternoon, but if I miss the call, i will call you back..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted June 05, 2009 05:31 AM        Edited By: NOX on 5 Jun 2009 13:34
I got REAL smart one day in the garage, and took my bike to the track without the anti chatter rings........
broke a fiber, AND the big thing was, the bike would not repeat....., 60 and 330 were everywhere.......
Brock laughed at me on the phone in conversation, LOL.
Put them back in, and it was gravy........., and I never broke another fiber......., (knock on wood)
And my bike moves VERY hard in the first couple feet, which is where the clutch is hit the hardest....., to cut low low lights all day, you have to on the pro tree, and Dr. Joe will attest, that both me, and the guy I race with, who I set his clutch up too, will cut your freakin head off on the tree........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted June 05, 2009 05:48 AM
Scott, I replied to your email........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted June 05, 2009 11:42 AM
thx Nox
So Doug, did you run the anti chatter rings and small fiber in Rickys bike?
0.22868895530701 seconds processing time
