NOX
PMRA / TMRC Super Street 4022
posted May 10, 2009 05:55 PM
Bike weight
Okay,
At the PMRA race this weekend, I weighed my bike........
twice......
Granted, I am about 175 or so suited, as my leathers are not super thin.......
Total weight, of bike and rider.......... 575lbs
Bike alone........ 390 on the scales.........
Is this possible, moly arm, light wheels, light rotors, fiberglass body......, etc
I was talking with Bill and Joe about it......, and I let Bill sit on my bike, he will tell you it is light......, but 390?????
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted May 10, 2009 06:35 PM
you should have weighed yourself on the scales and that way you could compare to a set at home
i thought your bike was around 440?? with the other arm and stock wheels???
posted May 10, 2009 06:55 PM
I don't think it is possible, Nox. I know about what Shiphteey's bike weighs with BST's, etc...and I don't see 390 lbs. from your long bike.
posted May 10, 2009 07:32 PM
Did you fill the tires with helium?
Johnnycheese
posted May 10, 2009 08:39 PM
quote: Did you fill the tires with helium?
I bet he had 10wt oil in the motor so that saves (4qts times 30wt savings) = 120#
and if you only inflate the tires to 10 instead of 40 yu save another 30# per tire
LOL
greenbusa
posted May 10, 2009 10:50 PM
Thats why I was so heavy, I had 45# in my front tire and 20 in my rear tire, I weighed 825lbs at the pmra race saturday. I was 300lbs suited without the bike. By the way Johnny my electrical problem was the mps kill box, changed it out and my bike ran clean all the way through. I went 8.78@163 on 10# boost. Thanks again for the awesome tune!
400+ hp daily driver
kawasakijockey
posted May 11, 2009 04:42 AM
It is the clutch tune.....Saves 150lbs. lol
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
2000redrocket
posted May 11, 2009 05:25 AM
mine all stock with muzzy ti with me is 690lb i am now 145 with out leathers on probally 155 suited up. wow that is lite.
NOX
posted May 11, 2009 06:07 AM
It showed 575 with me on it........
So, it was very close to my weight.........
Thats why I had to ask the question........
If it showed me on it weighing like 520, I would have known something was up, but I have gained a few pounds....., eating salad every day gets old, and I am back up to 175 or so suited..., scales showed me at 185, and in some sweaty leathers, thats about right.
Weighed it twice, and I know my buddy's busa weighed 500 15 min later....., and it is heavy......
I lost a full 15 lbs taking my high pressure shift set up off the bike, along with the moly arm I just bought from Jack Cambra. I lost 15 lbs at least on the wheels this spring......, and have wave rotors on the bike.
Not sure where all this is coming from, but I will for sure weigh it again, and hopefully me and Dr. Joe can go down there together or something......, and really do some checking.....
But , if its right, that would explain why this thing front halfs so freaking hard after 60 ft with this little dinky motor......
I had -2 degrees timing in in this weekend just to slow down to 9.50, at Thunder Valley.....
something is up for sure.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted May 11, 2009 06:09 AM
Nitrogen..........LOL
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted May 11, 2009 06:12 AM
quote: Thats why I was so heavy, I had 45# in my front tire and 20 in my rear tire, I weighed 825lbs at the pmra race saturday. I was 300lbs suited without the bike. By the way Johnny my electrical problem was the mps kill box, changed it out and my bike ran clean all the way through. I went 8.78@163 on 10# boost. Thanks again for the awesome tune!
Well, that would be about right, Jr.'s bike weighed 510 or 515 with a sidewinder, and that turbo is heavy......
We need to do some double checking at the next event....., for science sake......
and let some of the guys look my chassis over......, maybe I have done some stuff that would save a lot of weight for you boys.......
oh, both fans are in the attic......, 1 gal of fuel. It did have 5 qts of oil in it......,
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted May 11, 2009 06:15 AM
Maybe Karl can bring the garage Barbi's, for technical support.......
And TFA can be our cheering section......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Edited By: Shane661 on 11 May 2009 14:15
Nox, I doubt you lost 15 lbs. on the wheels. ZX-14 wheels are heavier than the 12 wheels (At least the rear is). I lost about 15 going to BST's. You have Magnesiums, right?
The front 12R Braking wave rotors are a little less than 4 oz. lighter than stock, each. The rear is probably closer to a pound lighter.
Was your bike empty of oil, coolant, and gas when you weighed it?
Also, what is the air like where you race? Seems slower than what we have here...
NOX
posted May 11, 2009 06:24 AM
I was at PMRA, 1100 ft elevation for the track alone, before factoring air.
No, that was after a pass, right next to the ticket booth........
90-80 front tire, MCR rear. 4lbs lighter than a shinko in the back, and a couple lbs lighter than a 120/60 in the front.......
Forged Alum Marchesinis.
I have Galfer Wave Rotors, they are pretty damn thin, and light, over a lb in the rear, over my drilled stocker, and all. My arm weighs only 15lbs. Total with wheels and rotors I lost about 15. Bathroom scale, etc.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted May 11, 2009 07:07 AM
I'll be interested to see what you find next time you weigh it. Shiphteey's bike has the BST's, stock arm (should be under 15 lbs?), and a cut down tank, race upper without headlight...so that is what I am judging by.
NOX
posted May 11, 2009 07:19 AM
Yes, it should be very interesting.......
I would bet that stock arm weighs close to my moly arm.......
I took the N2O mount out of it, and the air tank is in the arm, so I have no extra tank on the bike. Does he have fans on his bike? They are very heavy, and my bike came with two.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted May 11, 2009 07:41 AM
All blinker fluid, and Kanuder Valves have been removed as well.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted May 11, 2009 08:13 AM
Do you have a cut down tank also? Shiphteey's is quite a bit smaller than stock...
NOX
posted May 11, 2009 08:21 AM
No, its not. I do intend to get a catalyst fiberglass tank over the winter, and some new paint......
Not sure if that will get done though.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted May 11, 2009 09:23 AM
quote: No, its not. I do intend to get a catalyst fiberglass tank over the winter, and some new paint......
Catalyst makes one for the 14 also; I'm just not excited about draining it all of the time...
posted May 11, 2009 01:00 PM
Funny post
NOX
posted May 11, 2009 01:52 PM
quote: Funny post
Hows that?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
Thats my main issue with it, is taking the good fuel out, and putting in pump gas at the end of each day.....
Until I run heads up, I am not sure if it is worth it.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
chavcat
posted May 11, 2009 03:14 PM
Nox - are you using a single Galfer rotor on the front now?
NOX
posted May 11, 2009 09:40 PM
No, not yet, still running two......., I do not like the looks of one rotor, but, I am going to do some testing and if I need that last little bit, to go as fast as I want, then I will take it off.......
I have some special weight I can replace it with.......tee hee.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
