BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Clutch or gearbox knock? NEW TOPIC NEW POLL POST REPLY
Lorcan
posted August 12, 2002 08:27 AM
Hi guys. I'm hearing a clunking or knocking sound from the clutch or gearbox area (not sure which) in 1st gear only when launching. Any ideas what it could be? Bike has a Muzzy hub. It only seems to happen when I lauunch hard. (Hard for me is 1.56). Thanks for your help.
810cc - 211mph: www.750turbo.com
  Ignore this member    Click here to visit Lorcan's homepage.
madmike
posted August 12, 2002 08:38 AM
Have you opened up the cluch and looked yet? start there, you could have broken fibers, which would be an easy fix.
MM
Lorcan
posted August 12, 2002 11:43 AM
Haven't opened her up as the clutch still works fine. Will have a look tomorrow.
Thanks.
VINCE12
Designated Drinker.
posted August 13, 2002 06:21 AM
Have you checked your chain,adjustment,sprockets???
I've seen some bikes with loose chains recently at my local track,,,they all made a clunking sound when launching!!!Chain looked like it was banging on the swingarm or something!!!Hopefully this is all it is!!!
Lorcan
posted August 13, 2002 11:33 PM
Plates and basket are fine, the chain was freshly adjusted although it clatters a bit on the bracing of the JMC arm we are using. I don't think the noise is that though - it's coming from the engine. If it was the chain it would do it in other gears too, right? Maybe the shock absorbers on the back of the clutch basket? Kawasaki brought out a revised basket (new part number) in 2000 and we still have the original in it. Then they changed the basket again for 2001.
BA
posted August 14, 2002 10:26 AM
if it's only in 1st gear, and only when launching (ie. heavy load), could it be a gear tooth? Maybe worn or.....worse?
Lorcan
posted August 14, 2002 10:37 AM
It's not present on ordinary riding/acceleration in 1st gear, so i don't think it's a gear tooth. According to Kawasaki UK, the spring rate of the shock-absorbing springs on the back of the clutch basket was altered during 2000. I just thought some of you racers might have heard the same noise, but obviously it isn't widespread. We're going to try a late-2000 model basket this weekend (unfortunately only on an old airfield, not a proper track) and I'll let you know how it goes.
0.30899310112 seconds processing time
