BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Dry Nitrous Spray Bar NEW TOPIC NEW POLL POST REPLY
Gixx1300R
posted February 05, 2008 04:29 PM
Coming Real Soon
JSCARB2
J&S RACING & PERFORMANCE
posted February 05, 2008 06:57 PM
nice!
OUTER BANKS NC
SHOP 252-473-5214
WE DO POWDER COATING & CERAMIC COATING!
SOMETHINGS COMING DOWN ON THE BANKS!
2002 ZX-12R
2006 ZX-14
1993 CBR900RR DONT BE FOOLED!
2006 BUSA LIMITED
2002 VTX1800C
1998 ZX-11D
1988 SUZUKI INTRUDER 700
Gixx1300R
posted February 06, 2008 04:39 PM
It will be universal and fit all Sport Bikes
JSCARB2
posted February 06, 2008 04:48 PM
what kind of price?
OUTER BANKS NC
SHOP 252-473-5214
2002 ZX-12R
2006 ZX-14
2006 BUSA LIMITED
2002 VTX1800C
1998 ZX-11D
Gixx1300R
posted February 06, 2008 04:50 PM
Sorry,I was informed by Mike not to post a price in this section. Just keep an eye out in the Classified section in the next week.
ninja12
posted February 06, 2008 06:15 PM
interesting but can you explain the jetting, mounting and why the bar is so large?
Gixx1300R
posted February 06, 2008 06:54 PM
The bar is only 5/8. The ends are tapped and will be mounted there. This will allow you to pivot the bar and aim the nozzles. Each Nozzles have a .134 orifice. The bar will be mounted above the velocity stacks and spray downward. This should not interfere with airflow.
posted February 07, 2008 04:56 AM
where do you put the jets at?
posted February 07, 2008 07:50 AM
could put them at the solenoid like a dynotune kit
TRNorBRN6001
posted February 07, 2008 07:56 AM
Jet, might be like the nos wizard setup right after the Pulsoid, I mean solenoid.
Becareful when installing not to bend them lines to tight, I think a couple
people have had problems with that.
TFA 200MPH CLUB MEMBER!
ninja12
posted February 07, 2008 08:01 AM
No jet changes allowed? Any pictures of this mounted?
With the feed lines coming from the back I'm having a hard time understanding the mounting system. Does it hang from the top/airbox with the tips inside the stacks?
Gixx1300R
posted February 07, 2008 01:08 PM
Pics of the installed will be in a day or two. A single jet will be installed at the base of the showerhead.
posted February 07, 2008 05:43 PM
that seems to far away to be efficent...
Gixx1300R
posted February 08, 2008 03:25 AM
The needles are 2 3/4 inches in length
posted February 08, 2008 06:10 AM
i think he ment the jet, not how far the needle was from the stack
Nukedog
posted February 08, 2008 04:57 PM
Why would where the jet is located matter? The jet puts nitrous to the shower head to feed the lines. Just like a water faucet right? Seems like most other spray bar systems are the same as this and effecient as well...
02 Busa...Turbo...
09 YZF-R6S...
Gixx1300R
posted February 08, 2008 05:01 PM
I have found that if you use a straight manifold (were the 4 holes are side by side)the Nitrous isn't distributed evenly. Nitrous is compressible so it will load up on the ends. A Showerhead must be used to get the Nitrous evenly PERIOD!!!! I used an Alicat to check the flow rate.
posted February 08, 2008 05:14 PM
im not sure, maybe most guys are just used to wet systems???
Gixx1300R
posted February 08, 2008 05:20 PM
True but with the correct setup,A dry system can spray as much as a wet system
Gixx1300R
posted February 08, 2008 05:25 PM
This is my Dry system. I have sprayed as much as a 200 shot.
posted February 08, 2008 05:36 PM
haha i was just looking at those pics the other day on the psycho board.
Im thinking about something similar. i had an idea to put the nozzles in the resonators spraying up and back into the ram air tubes. that way they dont hurt flow any(i know its just a tiny bit) when off spray
Gixx1300R
posted February 09, 2008 08:08 AM
Gixx1300R
posted February 14, 2008 01:57 PM
Gixx1300R
posted February 21, 2008 12:04 PM
Gixx1300R
posted March 01, 2008 01:53 PM
This is the complete kit
0.30210208892822 seconds processing time
