BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Crank trivial info NEW TOPIC NEW POLL POST REPLY
NOX
PMRA / TMRC Super Street 4022
posted December 09, 2007 08:18 PM
Crank trivial info
2002 crank 26lbs
2001 crank 24 lbs
2001 crank with 2002 flywheel, 23 lbs
on ye old walmart bathroom scale. We will see what kind of difference it makes in et if any next season.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
woppi
posted December 09, 2007 11:54 PM
i have heard from !!
different crank weights !!
and different alternator / flywheel !!! i know -- they are different !!!!!
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
Y2KZX12R
CompetitionCNC.com
posted December 10, 2007 04:29 AM
Nox, you will need to check the balance on that combo. If the flywheel is neutral then its no big deal but if it isnt then it could cause problems. Spin it up with the flywheel on the crank to check.
Y2KZX12R
CompetitionCNC.com
ninja12
posted December 10, 2007 08:43 PM
2002 crank 26lbs
2001 crank 24 lbs
recheck your weights, noway it weighs less with the flywheel than without.
I know of a 2002 with 2000 crank that has been around from a while.
seems to be holding together pretty well. everything except crank is 02 .
posted December 10, 2007 09:59 PM
im guessing he means 01 crank + 01 flywheel is 24 pounds meaning the 02 flywheel is a pound lighter than the 01 flywheel
NOX
Sorry, the first two figures were with the flywheels, of the same year and crank, assembled.
2002 crank and flywheel, 26lbs
2001 crank and flywheel, 24 lbs
2001 crank, with 2002 flywheel, 23 lbs.
Before I did this, I made some calls. Coby Adams said go for it, no probs at all, and it will be balanced just the same, only lighter.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
woppi
posted December 11, 2007 03:50 AM
@nox
what i know --- you have to use the 2002 alternator to ?? !! ??
i dont know - if they are the same ??
woppi
NOX
posted December 11, 2007 06:25 AM
that is why I had to switch flywheels...........
They are not the same.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
TRNorBRN6001
posted December 11, 2007 07:07 AM
Maybe 02 cover as well? Connectors are a little different as well between 00-01 and 02+, but that should be easy to rectify (no pun intended).
TFA 200MPH CLUB MEMBER!
NOX
posted December 11, 2007 08:11 AM
I have an 02. All else is going back stock, except the 2001 crank.
Yes, if you did a flywheel swap on a 2001 , you would have to change it..........
Do I still get to call the motor "stock", lol
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted December 11, 2007 10:12 AM
just call it a stock 2001 and a half lol
NOX
posted December 12, 2007 06:57 AM
I like that...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.21266293525696 seconds processing time
