BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: How many guys running Dry shots without window switch? NEW TOPIC NEW POLL POST REPLY
posted August 28, 2007 08:41 AM
Anyone using the dynojet hub/ lcd relay output to trigger auto shift or their nitrous?
How has it worked for you?
Texas12R
posted August 28, 2007 06:07 PM
Im also interested.....Ive wondered why I havent heard of anyone using the hub.
I plan on it....but I move at the speed of smell...
I was going to use the hub output to pull in a relay for the shifter and or 40 dry shot
posted August 28, 2007 09:08 PM
Thats my plan, but I also have TPRS-002 , window switch from schnitz just incase it is deemed necessary...
I am a little weary running 50 shot, and having the shifter jam, or blow a shift, or the tire spin up too fast to kill the nitrous before it hits the rev limiter..
Scared of the nitrous in the rev limiter.... ka boom $$$
Still lookin for some input from some of the pro's here...
shiphteey
posted August 29, 2007 03:49 AM
I footshift using the horn button to spray. 40 all day no probs, no wheelies in 2nd w/a stock arm lowered.
I will be air shifting soon so the horn button will be shifting, and the right hand will be spraying. I thought about using the window switch but for what I'm doing (more LSR focused than drag) using the starter button is fine w/me. If you ran the strip a lot I'd go w/the window switch....especially you stretched bikes. Stock wheelbase doesn't spin up much w/my pirelli unless the track really sucks. For now I'd make an n/a pass, make sure there isn't any spin, then a small shot, then do your normal larger shot.
But windown switch sounds like a good idea. I have an extended rev limiter, hopefully that would help me out a teeny bit if I can react quicker if I was getting tirespin on the button.
A.
ninja12
posted August 30, 2007 07:57 AM
I did, but I 'm going to add one to my wet kit.
It won't keep you off the limiter if you miss a gear, unless you shift around 10,500
It will lessen the impact, and duration of the mishap.
Usually you don't know you missed a gear until the rev limiter tells you, then you get off the
gas and spray.
Direct injection and very short lines will help alot.
If you fog the box like Lawson then it very progressive on and off full nitrous power
posted August 30, 2007 08:13 AM
I am using the muzzy dry manifold...
thinking it may take too long to clear the intake of the nitrous anyway.... don't know...
0.33095192909241 seconds processing time
