BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: are there any soft 240s out there! NEW TOPIC NEW POLL POST REPLY
madkawracer
supercharged05zx10-182hp06zx14
posted December 27, 2006 05:09 PM        Edited By: madkawracer on 27 Dec 2006 17:10
I just picked up a sweet zx14 fresh out the box baby! H2O cycles has a 240 kit,10 over arm,chrome 2lb nitrous bottel,Jacksonville Powersports hooked me up with a Muzzy sidewinder and PC3.Stock Mild to Wild provided me with a TRE. Now I just need to put the rubber to the road in case I need to line up against any Hyaboobsters.
zrxdean
posted December 27, 2006 08:50 PM
If you really need traction, I think you'd be better off with a standard sized rim, but I dunno, maybe someone makes a functional 240 tire. They are more show than go.
Congrats on the bike, good choice.
Dean
madkawracer
posted December 27, 2006 09:15 PM
Thanks man, this is my show bike. I already have a supercharged 05 zx10s that makes 270rwhp and a 05 thats having a 1157 stroker-nitrous motor built by 2 boyz racing
matt sterbator
Hiding in the bushes
posted December 27, 2006 10:21 PM
You'd do better with a 180/55 Shinko Ultra soft on a stock rim.
madkawracer
posted December 28, 2006 05:23 AM
I'm trying to find that gray area between show and go.I already run soft sinkos on my other bikes.
posted December 28, 2006 08:28 AM
the other option... is to buy a bottle of VHT... they sell it in the 1 gallon size and then you do a small burnout in the VHT. it will make your tire real sticky for 1 or 2 passes... I have personally never tried it but I have a friend who uses it all of the time, he has a 900 Honda that is bored out...
it sure would not hurt to try it... you would be out a lot less then a tire costs...
dwb
posted December 28, 2006 03:14 PM
i have yet to find a 240 or bigger that is speed rated for more than 140mph....just something to keep in mind.
madkawracer
posted December 28, 2006 04:13 PM
preciate it mike. It sounds cool,I'm going to try that asap.Seems like you've made a pass or two
NINJA12
posted December 29, 2006 04:55 AM
I've never seen a 240 with the soft compound.
Most of the zx12s and busas around can burn them at will.
Still a cool idea, show and go.
Good luck with the vht, but be very careful it's like industrial glue if you ever spill it.
madkawracer
posted December 29, 2006 05:31 AM
It's there, I just need to put the rubber to the raod.My question is does this stuff get stuck everywhere? And I've got to find the stuff.
posted December 29, 2006 08:07 AM
they did "slow" smooth burnouts... I am assuming so It did not fling the crap everywhere...
Yea I have a couple of passes under my belt...
NINJA12
posted December 29, 2006 01:33 PM
Any burnout is going to result in a fun clean-up.
With VHT a little goes a long way, so probably not much worst than usual.
madkawracer
posted December 30, 2006 09:36 PM
I just got a word from one of my builders that pirelli will be making a scorpion soft compound 240 in a couple of months!! yyeeaahh....
posted December 30, 2006 11:26 PM
if it is anything to do with motorcycles I would double or tripple that time... they might have some samples at the dealer show, but probably not production ready... I hope so though for your sake...
Lee
Dirt is fun too
posted January 22, 2007 11:48 AM
Roaring Toyz has been using the new 240 scorpion for some time now.
06' Red ZX-14
  Ignore this member    Click here to visit Lee's homepage.
serius blk
posted February 01, 2007 03:42 AM
I saw on pirelli site they have a 240 zr rated semi compound tire. I had the same idea. How do you like the supercharger on your 10. I was thinking about that for the 14.
madkawracer
posted February 02, 2007 06:44 AM
man its pretty cool, its controllable so it allows you let people leave or you can sleep the light and boost pass that azz. its like sitting on a rocket where as a turbo you cant predict how the boost is going to kick at high boost.but I have two stroker motor 10s one built by Coby Adams the other by twoboyz racing, though they are hella fast(the coby does 8.40 1/4 @179 on motor)they are not streetable. And the twoboyz is a bigger motor.My 14 will only have a fitty shot in case a busa gets out of hand! Jason at calisuperbikes is cool he'll be able to hook you up.But good luck that should be crazy power.
0.2227931022644 seconds processing time
