BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: gearing suggestions NEW TOPIC NEW POLL POST REPLY
oof440
posted February 02, 2007 03:20 PM
gearing suggestions
I just ebayed an 8 inch extended track dynamics swingarm for 370.00 and was wondering what gearing you guys would suggest. I'm 425 pounds, the bikes got a 2mm over, 13 to 1 big bore kit in it with stock cams and a 70 horse wet shot on it. I just kind of need a starting point for when I get it back together. I appreciate your help in advance.
posted February 02, 2007 07:10 PM
17-47...Hows your clutch???
You definately need a new rear shock!!!
osti33
posted February 02, 2007 07:34 PM
17-50 or 51
oof440
posted February 03, 2007 05:04 AM
The clutch is pretty much completely muzzys, billet basket etc. with I believe ape springs I bought from schnitz. What would you suggest I do for a shock, can I have mine spung and valved or should I just buy one new. Its not easy trying to go fast when your fat. Thanks.
posted February 03, 2007 01:20 PM
If you have the shock done already then your good...Clutch sounds good...
I mentioned the 17-47 because you have a piston kit and the shot of nitrous...By the way dont just snap the clutch out, come out at high RPM then SNAP the clutch 3/4s out and SLIDE the rest to prevent bog while twisting the throttle...Thats why I mentioned the 17-47...
Osti would know better than me, since he has a 12 with a motor, 6over arm and weighs over 200...
RICH CRAFT 1
posted February 03, 2007 04:02 PM
17-55=@11500=156 MPH
oof440
posted February 04, 2007 01:51 PM
I havent had my shock done yet. I was wondering who you guys would suggest to have it done. I was also wondering about air shifter recommendations. If I remember right the muzzys stealth nitrous kit I have already has part of the harness for their air shifter but I didnt know if I would have better luck with someone elses. I'm open to any suggestions you guys have, I just wanna go fast. Thanks.
0.21831512451172 seconds processing time
