BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: dyna shift minder NEW TOPIC NEW POLL POST REPLY
johns
posted May 18, 2002 02:57 PM
dyna shift minder
anyone using the dyna shift minder and shift light on you're zx-12? can the dyna use the stock tach input wire to sense rpm? This does not appear to me to be an option since the tach input is a square wave DC input (the manual says 3000 rpm = 100HZ signal). I also can't tell from the svc manual wiring diagram what color wire leaving the CPU in the tail section feeds the signal to the tach.
2006 ZX-14 (sold)
2012 ZX-14R (Brock's Perf. project bike Louisville Slugger)
2013 Honda VFR1200F
2003 124 C.I. H.D. Super glide
ra12r
posted May 19, 2002 07:05 AM
Yes, I am using it with the dyna shift light. Works very well attaching to the light blue wire in the top left corner on the back of the tach.
kcadby
posted May 20, 2002 06:57 PM
DITTO...
johns
posted May 26, 2002 06:51 AM
thanks guys it works perfectly. mounted the box with velcro on the plastic tray in front of insturments. mounted light inside windshield with longer than stock phillips bolt on center right windshield hole after tapping the mounting hole for the light. worked out very cleanly.
2006 ZX-14 (sold)
2013 Honda VFR1200F
ZX12Girl
Adrenaline Junkie
posted May 27, 2002 07:01 PM
I have one also....works great!!!
Mounted mine in the smae place john.....enjoy!!!
anesthesiac12
posted June 08, 2002 07:02 AM
I have two myself.......
0.33275699615479 seconds processing time
