Cowboy
posted March 16, 2002 04:55 PM
Shift minder install
Do I need the haya101 thingy of can i just use the tach wire?Where's the best place to tap into it?Thankyou
oldkawboy
posted March 17, 2002 07:52 AM
Cowboy,
Since I mounted my box in the trunk it was easy for me to tap into the light blue wire at the ECU. Some people splice into the feed going into the back of the tach. You can trace the wire out in the shop manual.
Dan
Cowboy
posted March 17, 2002 08:42 AM
thanks Dan
ra12r
posted March 21, 2002 04:33 PM
Is the light blue wire on the same side as the coil/plug wires or on the left side?! Does the light blue wire go to the tach and turn green or what am i looking for?!?!?!
anesthesiac12
posted March 22, 2002 09:45 AM
I tapped into the tach wire on the back of the instrament cluster. On the plug in the back of the inst. panel,{as you are looking at it) its the top left wire. I think it was white. Also made mouting plates and mouted minders here.
anesthesiac12
posted March 22, 2002 09:46 AM
Im not certain of the color, but its top left on the plug
H
posted March 24, 2002 07:42 AM
Edited By: H on 24 Mar 2002 07:43
Anesthesiac12,
I remember some pics of your 12 with the custom lights in the tach face. Can you post them again?
Thanks!
anesthesiac12
posted March 24, 2002 09:44 AM
anesthesiac12
posted March 24, 2002 09:46 AM
they are for the N2o. The green one tells me the system is armed, the blue is for the n2o sylinoid and the red it for the fuel.
