BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Thanks Kevin Cadby NEW TOPIC NEW POLL POST REPLY
Speedfab
posted May 25, 2005 07:04 AM
Thanks Kevin Cadby
I just wanted to publicly thank Kevin for staying late last night and running my pile of crap so I could tune the air/fuel. Thanks buddy, you da man!
  Ignore this member    Click here to visit Speedfab's homepage.
zrxdean
posted May 25, 2005 09:51 AM
No surprise there - Kevin is committed to doing what it takes to help people, and to do things right.
Soooo.... how'd it RUN?????
Dean
Speedfab
posted May 25, 2005 11:52 AM
Dean
Not too bad.
kcadby
posted May 25, 2005 03:12 PM
Yer...VERY welcome Sir
I like BOOOST!!!
It ran/runs like a BoneStock Bbusa with a "NICE" one-off Turbo System on it LOL...
Most beautiful exhaust/dump pipe you will ever see on a bike IMO...
It actually exits through the stock (not cut) opening in the fairing...SO very cool looking...
SOUNDS good/cool also since it's kinda like a squashed megaphone (TALL and narrow at the exit but round of coarse at the turbo)...
The welds and polishing are so perfect that it looks like one piece...even though it's fab-ed out of at least 5??? pieces of stainless tubing/plate!?!?!?
So coool looking that it's like a same to cover it with the fairing
Until you notice how it fits the contour of the fairing opening anyway
Gonna see Bri's SpeedFab built ZX12 turbo spinning the drum here soon...
I LIKE boooooost!!!
your car is slow
Fuck Nitrous...Got Boost?
posted May 25, 2005 05:58 PM
So closeeeeeeee.
Do not taunt happy fun ball!
kcadby
posted May 25, 2005 06:01 PM
COOOOOOL!!!!!!
wherrrrrrWherrrrrrWHERRRRRR!!!
osti33
posted May 25, 2005 06:06 PM
So closeeeeeeee.
Sweet!! I can't wait to see that beast go down the track!
zrxdean
posted May 26, 2005 07:34 AM
What's left Bri? Can't wait to see it.
Speedfab
posted May 26, 2005 07:57 AM
We fire it today.
kcadby
posted May 26, 2005 04:20 PM
krexken
posted May 26, 2005 05:35 PM
Pics! Small crappy ones though. I'm still on dial up. LOL
osti33
posted May 26, 2005 06:42 PM
We fire it today.
Well...How did that bad boy run??
your car is slow
posted May 26, 2005 09:03 PM
Didnt get around to it...had other technical difficulties with a suzuki instead.
By the way kev....is the dyno available for tomorrow night?
kcadby
posted May 27, 2005 09:44 AM
Do you mean TONIGHT???
If so...NO!!!
I'm going RACING at Jax
I'll be here Sat. "after work" for sure...
your car is slow
posted May 27, 2005 11:24 AM
oof...ok...so a negative on tonight...boooo
Good luck tonight!
kcadby
posted May 28, 2005 10:08 AM
So...it runs???
Call me YCIS if you want to run it tonight???
Anytime after 4-5pm...I will probly be here LATE...the way it's looking right now...
Just finished 2nd Dyno Tune of the day...ooof...
your car is slow
posted May 28, 2005 10:10 AM
Tried to fire it last night...MMS isnt firing the plugs for some reason (everything else works fine).
Ill call you later today from the shop if we can bring it by.
kcadby
posted May 28, 2005 11:56 AM
OK...
If you don't still have it...tracy has my Cell#...
I will NOT answer shop phone after hours...It even freekin rings on SUNDAY!?!?!?
Speedfab
posted May 28, 2005 12:32 PM
Unless something magic happens here in the next hour or two, I'll have to wait until I can call a tech at Muzzys and find out what the hell the problem is. The signal from the crank trigger is present and functional at the correct pin on the EMS box, but for whatever reason the EMS isn't seeing engine RPM. Everything else works fine.
I have an Accel Gen 7 4 cylinder system in a box here, I'm almost pissed off enough to set that up and take this damn DTA thing out back and shoot it.
kcadby
posted May 28, 2005 03:26 PM
Try PM-ing SWFT...he is the only person I know that has used the MMS...
Try dougmeyer also???
posted May 28, 2005 05:23 PM
Did you run the injector / spark test program? If not, do. If it's not sparking and clicking it's probably a power source problem to either or both depending on the buzz, click or lack thereof. If it buzzes and clicks and it won't go bang look at timing (trigger wheel) and fuel pressure.
Doug
Speedfab
posted May 28, 2005 05:41 PM
Doug
Doug, the test program functions perfectly - box has no problem driving both injectors and coils. Fuel pressure is present and accounted for and the pump cycles properly. The trigger wheel inductive pickup is functioning with proper voltage pulse all the way to the pins on the ECU. For whatever reason, the ECU seems not to be processing the trigger signal. If you have any ideas in that area, please let me know. You can call the shop at 904-298-0005 or my cell 904 635-9957 if you have time. Thanks.
I have used DTA systems before and have never seen this prob.
your car is slow
posted May 29, 2005 09:36 AM
Big thanks to doug for identifying the problem (in email)....If ANYONE can get ahold of "COWBOY" pleas please please have him call/email/pm me ASAP!!!
Brian
kcadby
posted May 29, 2005 09:35 PM
Thank you Doug
Call me Mon. afternoon BRIAN and let me know what-up...
Will sleep in after working late/EARLY!?!?!? on my bike (for a change)
and Anthony's TurboBbusa...
your car is slow
posted May 29, 2005 11:40 PM
Eh...we are missing a part...so I doubt anything will happen monday. Apparently the EMS requires a special crank sensor wheel that did not come with the stuff COWBOY sent me...so either Ill have to see if he can find it and get it to me asap..or order another one from muzzys and have it overnighted. Chances are Muzzys isnt open monday...so earliest I could have it would be wed :/
0.27557277679443 seconds processing time
