BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: free hp mods??? NEW TOPIC NEW POLL POST REPLY
ZX12Girl
Adrenaline Junkie
posted February 02, 2002 10:26 PM        Edited By: ZX12Girl on 3 Feb 2002 18:02
Free HP mods???
Ok! I have done the Y2K mods. I was wondering if there are any other free or easy mods out there???
- Kleen Air removed
- Ignition Advance
- Heat Blanket
- K & N Filters
- 17 tooth Sprocket
- Cam timing
- Chain tension / lube
- Front tire pressure
- Rear alignment
Done! Stuff like that????
posted February 03, 2002 06:41 AM
Ditto for me Angie!!!
jessz1
Half the wheels, twice the fun
posted February 03, 2002 06:58 AM
Any weight you can remove is basicly free. Looks like ya got most of the "real" improvments done.
  Ignore this member    Click here to send jessz1 an AIM message.
posted February 03, 2002 08:36 AM
Liposuction. LOL... hoover in the garage....
BA
posted February 03, 2002 11:21 AM
HOW CAN YOU BE FORGETTING THE FITCH FUEL CATALYST!!!!!
Do you always check the tension on your chain? Keep it real clean and well lubed? Front tire pressure not low? Lightweight synth. oil? Rear Tire alignment? Crankcase ventilation?
.....and the yet to be infamous throttle body stacks!!
better stop there, don't want to divulge all the secrets!!
BA
posted February 03, 2002 11:51 AM
whoops, can't forget cam timing!!
jessz1
posted February 03, 2002 02:58 PM
Oh, I figured she allready did all that!!
INTRA
posted February 03, 2002 08:14 PM
How about removing the "Resonator tubes"or whatever they really are,and pull the filters or modify them,then there's the tps adjustment..
Y2KZX12R
CompetitionCNC.com
posted February 04, 2002 10:31 AM
If you are running the stock pistons, you can remove the block shim for about a half point bump in compression from 12.2 to 12.8 to one.
Wraping the pipe is worth a few hp.
Keep the cranking compression up by selecting "good" cam timing. I'm not so shure you dragracers want 105/100.
I think moore R&D is needed in the cam timing department.
105/100 is good for power above 10,800 rpm. (top speed runs)
How many of you people had "crap" behind your intake valves?
Y2KZX12R
CompetitionCNC.com
hott-rodd
posted February 04, 2002 10:36 AM
How much work is involved in removing the block shim.
Do you have to remove the head, is there a way to loose the bolts and work it out.
Y2KZX12R
CompetitionCNC.com
posted February 04, 2002 11:09 AM
You must remove the head and lift the block an inch or so.
Snip the shim and remove it. You must use a SMALL amount of case sealer after cleaning the surfaces with clean rags and brake cleaner.
The cams MUST be retimed and the intake valve to piston clearances checked carefully. Start the intake cam at 106 CL and move towards 103 CL untill you get to .035" piston to valve clearance. This will be at about 104 CL.
Y2KZX12R
CompetitionCNC.com
madmike
posted February 04, 2002 01:14 PM
Rember that if you have a full Ti, pipe, DO NOT Wrap the header!! it will become brittle from the heat!
ZX12Girl
Adrenaline Junkie
posted February 04, 2002 02:58 PM
WOW!!!! Too Cool!!!
You guys are awesome!!!! I have a couple more now!!!! Thanks a million~!!!
Any more little hp secrets????
INTRA
posted February 05, 2002 12:51 AM
I know one thing that worked on mine,when the 1270 was in,the cams d'greed(105,100),we also had a "thin"head gasket,(strait from my buddies machine shop)then we adv.timing from 0 to 2.5,then to 5 degrees,lost power,then cut media only out of air filters,then boom!-instant Hp,first time my bike broke 190hp,(193hp) on b32 gas,somehow,advances in timing only produced gains when filters were gutted or out,yes,I did remove the resonators and taped off the holes,it sounded a lot better too-but once I started spraying it with the cams degreed,it never dynoed in the 190's again,but also retarded timing below stock,that would explain for the power drop,my tps was also set,and yes,better throttle response,and I will say,the bike with all these mods had the most agressive lope you have ever heard come from a 12,it would go from 400 rpms to 1400 rpms with half lope between-fuckin gave me the stiffest wood.
Y2KZX12R
CompetitionCNC.com
posted February 05, 2002 11:31 AM
Angi, I cant give you ALL the info! I have to save some of the serious power mods for myself!
Y2KZX12R
CompetitionCNC.com
jessz1
posted February 05, 2002 02:58 PM
When you put that extended arm on you will need a longer chain. Put a non O-ring chain on it. Good for a couple of ponies!
ZX12Girl
Adrenaline Junkie
posted February 05, 2002 03:22 PM
Check!!!!! Already done!!!
BA
posted February 07, 2002 09:44 AM
hey, you'll be cranking some very sweet times when you get out there.
I can't wait to hear back from you when the weather turns better!
0.22274398803711 seconds processing time
