BIKELAND > FORUMS > ZX12R ZONE.com > Thread: found better exhaust gastemp meter! NEW TOPIC NEW POLL POST REPLY
posted October 02, 2003 01:38 PM        Edited By: VincentHill on 7 Oct 2003 13:48
Found Better Exhaust GasTemp meter!
http://www.professionalequipment.com/xq/ASP/ProductID.1211/id.22/subID.177/qx/default.htm
After doing all of my research, I realized that reading from the pipe would just be too far behind the profile! So for a Whopping $139.00 including delivery, I will be drilling a little hole into the pipe and installing this Thermo Couple and read the exhaust Gast temp real time even while out for a "RIDE" at Maxton! I am going to know what is going on with that engine, one way or the other!!
Now I can fully test my NOS Set up!
Otis, I would have never found this for this price if I had not been inspired by a lack of money! I saw them for a lot more and less temp also. Now this is what I am talking about!
posted October 02, 2003 04:01 PM
Temperature range:
0 to 1,832°F
(18 to 1,000°C)
Accuracy at 70°F (23°C):
CE=0.95
30 to 950°F
(-18 to 1,000°C)
±2% of reading or
±3.5°F (2°C)
whichever is greater
Response time:
500 msec
Spectral response:
7 to 14um
Emissivity:
0.3 to 0.99 adjustable
Display resolution:
0.1°F and 0.1°C or 1°F and 1°C
K-type range: -40 to 2,192°F (-40 to 1,200°C)
Ambient operating range:
32 to 120°F (0 to 50°C)
Looks like 3 to 5% + or - Accuracy without the probe and 100% accuracy with the hand held probe.
addisonzx12
posted October 02, 2003 04:13 PM
OK, How are you going to use the infra-red tester to test your NOS hook up?
deathpulse
posted October 02, 2003 06:52 PM
WHOA... I'm so non-techie. That thingamajig looks like a star trek phaser gun!
Otis
Captain Kickstand
posted October 03, 2003 02:49 AM
Good deal Vinnie
It's a free country brother
posted October 03, 2003 07:10 AM
Thanks Otis! I plan to use this as a back up test to the Air Fuel Ratio. I plan to take some readings without spray and then with spray and see what the heat temp difference is. I am looking for + 30 degrees. If Higher, I will add more fuel, if lower, I will add more NOS.
0.27248287200928 seconds processing time
