BIKELAND > FORUMS > ZX12R ZONE.com > Thread: FI light come on when decelerate off throttle NEW TOPIC NEW POLL POST REPLY
Kaw Man
posted September 09, 2003 04:40 PM
The bike is a 02' ZX12 it just start come on. What could it be.
  Ignore this member    Click here to send Kaw Man an AIM message.
JoshDunn
posted September 09, 2003 04:50 PM
Sorry but there are so many things that could cause that it's hard to say. Is it stock?
Kaw Man
posted September 09, 2003 05:04 PM
yes it stock
It had a PC111R and Muzzy pipe
posted September 09, 2003 06:55 PM
try dicsonnecting the powercommander
Hells Dark Lord
living life, and loving it.
posted September 10, 2003 04:50 AM
that woudl be the first thing I did was disconnect the PC...anytime anything happens that should be ther first thin ya do.....lol
Kaw Man
posted September 10, 2003 02:55 PM
I did unplug PC111R
The FI light still came on.
Hells Dark Lord
posted September 10, 2003 04:03 PM
sounds like a fuel pressure problem in the FI system....have no idea what would cause it though.....
vozizm
Got Nothing Witty To Say
posted September 10, 2003 04:08 PM
i get the same
Kaw Man
posted September 10, 2003 04:38 PM
How much fuel pump pressure do I need
The 02' zx12 only have one gas line.No return line.I some help.
kcadby
posted September 10, 2003 05:39 PM
They usualy buck-n-surg when it's fuel pressure and can/DOES happen when the bike is very low on fuel...
Don't remember the FI light coming on when it did that to me (was 2-years ago though)
Are you sure it's not the oil-light??? I doubt it is but...better safe than sorry!?!?!?
Only other thing comming to mind at the moment is...loose/bad connection somewhere...
Kaw Man
posted September 11, 2003 07:15 PM
No its not the oil light.
Its the FI light. When I turn key off it reset. The bike run
good but when you open full throttle and close it the light
come on and stay.
Hells Dark Lord
posted September 11, 2003 09:42 PM
definately sounds electronic....but Kevin would know better than me by far.....
posted September 12, 2003 07:47 AM
The ECU doesn't KNOW (and therefore the FI light won't indicate a fault with) the fuel pressure. I'd be checking sensors and all plugs, especially the ones at the base of the tank. I have found that sometimes individual wires come unseated in the plug housing and when you push the plugs together the terminals do not fully seat on each other causing an intermittant fault. I have seen this in the regulator plug at the tail as well. Could be a loose ground somewhere as well. It does not take much to interrupt a ground. A little corrosion or dirt will do it.
Doug
Hells Dark Lord
posted September 12, 2003 01:39 PM
thanks Doug....knew we kept you kicking around here for a reason....
Hopefully this will help him diagnose his problem....
Kaw Man
posted September 12, 2003 05:56 PM
I will check the wire plugs in the morning
I hope this fix it because I want to go racing Sunday.
Kaw Man
posted September 15, 2003 04:01 PM
I like to say Thank You Doug M and Dark Lard
The problem was in the connection to the Booneville Box. I
fix it, thank to yall good men.
0.21648097038269 seconds processing time
