BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Calling all Mechanics( Need Help) NEW TOPIC NEW POLL POST REPLY
big12
posted August 21, 2003 07:23 AM
Ok here is the deal. I was riding my bike stop for a moment then notice bike didn't want to start (Like battery was dead). Hey I live on a hill. Rolled it clutch started the bike ran fine. Until I got to my destination then again bike didn't want to start. I took the battery out to check the connections because it seems that the clock keeps resetting itself when I try to start the bike. Connections seemed a bit loose on one end. Tightened it put bike back together. Jump started the bike with my car. Bike fired right up went down the street pulled a wheelie when bike came down everything went off bike stops running lights go dim and then I put the bike up baffled. Please help what could it be. Alternator, do I need a new battery. Now when I try and turn the bike on nothing happens very dim neutral light is all I get. No noses, not even the clatter I used to get when the battery was low. Not even the dials moving when I go to start it. Need help. Please advice.
  Ignore this member    Click here to send BIG12 an AIM message.
ninja12
posted August 21, 2003 08:08 AM
Battery is VERY LOW, You most likely have a chaging problem.
The bike will run without a charging system, like big racers do, but
you must keep the battery charged manually. Cranking requires the most
juices , so it's the first signal you get that something is wrong.
Then when you ran the battery all the way down it could no longer
fire the coils, it dies. Charge the battery manually and see if things get better.
Have the battery checked either way. It could be a weak battery or dead celll.
That's my .02
Keep us posted.
GreenGlenn
Ron Jeremy's Stunt Double
posted August 21, 2003 09:18 AM
If you discharge a battery that severly there is a very good chance it is toast. Make MadMike happy and just spring for a new Interstate battery.
If you love your bike, set it free. If it comes back to you....you probably highsided.
BigJ12
posted August 21, 2003 09:27 AM
I would be very suprised if it was not the battery. All that you have informed us says that's what it is. Change the battery and make sure you keep it charged if the bike sits for any extended period of time. I keep my trickle charger connected to my garage door opener (in the winter) so every time I open the garage door I get a 5 min charge to the battery. Invest in a charger if you don't have one already.
BigJ12
big12
posted August 21, 2003 10:19 AM
Thank you guys I will buy a charger first, than if the problem stays I will buy a battery from Mike You guys are great. Thanks again
EastBayDave
posted August 21, 2003 03:40 PM
ya know all our batteries are getting 3+ years old now....a little early to start seeing problems? Noticed mine's getting a bit tired too...starts ok, just cranks slower...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
necro
My Grandma Is A Virgin
posted August 21, 2003 04:31 PM
Why did the wheelie make a difference?
OZZY
need guberment cheese
posted August 21, 2003 05:04 PM
Probably rotten plates and one was knocked loose if the wheely gave a hard landing impact.
Put in a new battery.
necro
posted August 21, 2003 06:44 PM
Ah...
slug
Out in search of my mind...
posted August 21, 2003 07:00 PM
hrmmm the impact/kill sounds suspiciously like a bad connection
even with one plate shorted out, it would still have voltage differential. and the alternator would still be supplying power.
check the connectors where the alternator hooks into main harness. also check the regulator/rectifier unit (if equipped)
as far as batteries go....mine is still the stock unit. it was installed sometime in 1997/1998 period. it sat idle for better part of the year on showroom floor, then sat idle again for 3 month intervals every 6.
stator failed on me a few months after a nasty crash, and i ran battery dead. got stator changed, and recharged battery, and life has been great since.
yuasa sealed battery. it rulz.
street bike will get another yuasa if this one ever dies.
a battery made by gould (GNB) is also likely to be a quality unit. i have seen many a gould battery abused in the name of national defense....glenn has too ;P
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
posted August 21, 2003 08:21 PM
I would also say the battery is at its life end, a new Interstate will get you going strong!!
Mad Mike
necro
posted August 21, 2003 08:39 PM
big12
posted August 22, 2003 08:03 AM
I will check that out as well slug. You have made a good point regarding the connections I too thought it was a connection problem seeing that the clutch is not even a two weeks old.
0.24590802192688 seconds processing time
