MarkZX12RKX500
posted August 21, 2003 06:29 PM
HELP Hesitation problem
Has anyone ever had this problem ok I put a full muzzy ,power commander, block off plates and k&n filter
now the bike has a hesitation problem at take off other than that it is fine and it doesn't matter what map I use either.
frEEk
posted August 21, 2003 07:04 PM
if by "at takeoff" u mean around 2500rpm, thats normal. it's just a flatspot. can be partially fixed with a power commander.
jonwright
posted August 21, 2003 07:09 PM
If frEEK is right, mine has that, too. I have same set up as you.
frEEk
posted August 21, 2003 07:11 PM
u get it on a stock bike too. they all have that bloody flat spot. some days it's worse than others. but i believe adding a pipe without remapping the bike will make it more pronounced.
of course, i could be smokin crack too. i'm sure someone who knows better will chime in soon.
posted August 21, 2003 08:46 PM
well.. .I'd say you need to get a map loaded into yer power commander by the soulnds of yer other thread where yer playin with the buttonz!
just my $2 werth,... are you near any members of this site that might be able to show you how to use the thing?
rpmwfo
posted August 21, 2003 11:52 PM
I have the full muzzy, and after I installed it and rode it with the zero map, I had the bad stumble at 2500rpm. I didn't care for how the bike ran at all! I was worried that I had chose the wrong pipe. I liked the looks and the sound (plus it only seems right to put a muzzy on a kaw), but began thinking about changing pipes. It ran great from 2500 on up. Below that was like having the power turned on like a light. Too abrupt. I figured there had to be a way to tune the bike to run better. I know a custom map is the way to go, but I haven't gotten around to getting one made yet and I just wanted to ride for a few days after getting the bike running again. So I resorted to tweaking an existing map to try to fix the problem. On the existing map, I worked on a block of cells in the range of 0 -2500rpm portion and 0-20% throttle position. I advanced the timing and leaned out the 1500-2500 area.
I also did the pilot jet mod that is suggested on zx12.org. That helped the transition so that the power didn't come on like a light switch. I only wish I had hooked up a vacuum guage in line to the intake air pressure sensor with the stock exhaust so I could see what the vac. signal looked like.
After a few iterations, the map that I have now is working real well. The stumble has moved to around 2100 -2200 rpm and is very slight. The bike is pretty smooth to ride. Almost as good as stock (98% imho). I think a little more work and I'll have it. But, as well as it works now, I would rather ride it than screw with the map to make it better. Maybe a I'll spring for a map once the prime riding weather starts to fade.
After all this I am glad I went with the pipe I did. Awesome power everywhere, great sound (not any louder than my chopper), and a little difficult to tune (just takes patience- but worth it).
All I can say is that MUZZY's RULE!
Sorry for the long post. I just want to see the Muzzy pipe get a fair shake. I think they get a bad rap on the boards. Several people gave me good advice on them and I went with it. I'm happy I did.
Hells Dark Lord
living life, and loving it.
posted August 22, 2003 03:24 AM
i think that you all hit the nail on the head here. My bike ran smooth as silk (02 model) when it was stock, no hesitation or stumble anywhere. When I went to the full Muzzy system it picked up a flat spot around 2000-3200 rpms...With the PCII and the map tha t Kevin made, it now only has a slight flat spot right at 1500-1800. Then it pulls strong all the way to the limiter...
Put a PC on it and play with the bottom end of the map, or take it to someone if you ae like me and completely mechanically inempt....lol
MarkZX12RKX500
posted August 22, 2003 04:29 AM
I talked to muzzy and they told me to change the settings on the throttle control you have to use a ohm meter they fax me a paper on how to do it.
Have any of you tryed this?
also thanks for your input.
posted August 22, 2003 05:50 AM
uh... hey... before you start doing all of this have you actually personally loaded any maps into that powercommander?
k bryant
Sponsor
posted August 22, 2003 07:49 AM
My '03 had no hesitation at all stock. Did Muzzy, PC3r, Muzzy map, BMC. Hesitation as others have noted at 2500 rpm. I'm just dealing with it... No big thing, but it does annoy me in traffic. Other than that, it runs flawlessly, so I just don't want to screw up the rest of the rpm band.
jonwright
posted August 22, 2003 11:52 AM
K, Sherman had a custom map done - his bike, with Muzzy etc. had same problem. Yeah, it's really only bothersome in traffic and whatnot. Given the amount of backroad burning we do around here it's not a big deal.
But after his custom map it was MUCH smoother on-off throttle transitions and also smoothed out the overall map. Didn't sacrifice the rest of the curve.
Dyno operator had a sniffer, though.
MarkZX12RKX500
posted August 22, 2003 01:20 PM
I changed the throtle sensor like muzzy told me to and it helped it was easy to do. if anyone wants the info on how to do it let me know.
