BIKELAND > FORUMS > ZX12R ZONE.com > Thread: throttle value on pc3r software. NEW TOPIC NEW POLL POST REPLY
GOZR
GOZR
posted July 28, 2003 08:01 PM        Edited By: GOZR on 28 Jul 2003 21:02
Throttle value on pc3R software.
On the throttle value to be at O% i set it at "54" than to be at 100 i set it to "213"( originaly 214).
I went for 3 days on a map with "0" ignit advance than the third day i look into my map "get curent" and i see "3" everywhere instead of "0".
The bike was cooghing a bit at 3 to 20 % throttle.
reloaded at 0 value .. will try again tomorrow but i think the bike is telling me to buy a Muzzy advancer....
-G
posted July 28, 2003 08:10 PM        Edited By: dougmeyer on 28 Jul 2003 21:10
Gozr, you're doing it wrong. Just set push the correct button when "closed" and the other when "open" and finish.
Don't pay any attention to the numbers that result.
The threes are correct as a starting point.
Doug
GOZR
GOZR
posted July 28, 2003 08:34 PM
ok thx i'll try
-G
GOZR
GOZR
posted July 28, 2003 08:45 PM        Edited By: GOZR on 28 Jul 2003 21:46
I must an idiot because i can't figure it out wich is the Correct button?
if i don't pay attention to numbers and the number is at 538 % open something how the computer will reconize it?
-G
12RPilot
posted July 29, 2003 04:57 AM
The numbers aren't percent, just a value if I remember correctly. Also, some software had a bug that switched the wide open and fully closed buttons on the throttle setting window. If I go through the steps for setting the throttle position like they tell you to, I end up with 100% showing at the top of my screen when idling. I have to hit the "throttle open" button when the throttle is actually closed and vise versa. I've heard of several others with this software problem. I hope I made sense to you here.
NESBA #209
your car is slow
Fuck Nitrous...Got Boost?
posted July 29, 2003 06:33 AM
I dont recall which is which (top or bottom) but the LOWER number should be the closed one. There should be a "set" or something button next to each number in the software.
Do not taunt happy fun ball!
GOZR
GOZR
posted July 29, 2003 06:44 AM
wicth software version?
-G
your car is slow
posted July 29, 2003 06:58 AM
2.7
(On a side note...I cant open it up to give you screenshots on this laptop...it would seem that without the PC3 connected to it....you cant open the adjustment screen)
GOZR
GOZR
posted July 29, 2003 07:03 AM
yea i have also the v 2.7 .8.22
-G
your car is slow
posted July 29, 2003 07:32 AM        Edited By: your car is slow on 29 Jul 2003 08:33
Ok..here you go
http://www.powercommander.com/man_chp9_pg29.shtml
GOZR
GOZR
posted July 29, 2003 07:06 PM
thx
-G
Megabyte
posted July 31, 2003 09:12 PM
Same Topic Different ?
Any advantage/disadvantage to setting the wide open (full) setting so it reads 103-105 at full throttle ?
posted July 31, 2003 09:16 PM
Disadvantage only in that it isn't right. You are assuming that there is some meaning to the number vis a vis 100%. There is not. Just follow the instructions and let the numbers be whatever they are. They will then be "correct" for your bike.
Doug
GOZR
GOZR
posted July 31, 2003 09:32 PM
Mine read 100/ 101 for wide open..
-G
your car is slow
posted August 01, 2003 05:51 AM
Try it a couple of times.
Wring the throttle back and forth (making sure to hit the stop on the WOT mark with some force).
Then run the Throttle set again. I had to do it 3 or 4 times before I got a perfect 0 - 100
0.30654907226562 seconds processing time
