BIKELAND > FORUMS > ZX12R ZONE.com > Thread: how to manualy turn on the fuel pump NEW TOPIC NEW POLL POST REPLY
Cowboy
posted July 31, 2003 07:09 AM
I'm draining the fuel was showed once which wires to jump on the fuel pump relay but have since forgotten.Does anyone know?
Cowboy
posted July 31, 2003 07:27 AM
figured it out.You jump the white with red strip to the other corner terminal which has a solid red.Then turn the key on and it pumps.This is for a 2000 model and not sure if its the same on newer models.
ninja12
posted July 31, 2003 12:26 PM
where is the fuel pump relay located?
posted July 31, 2003 03:26 PM
Up by the fuse box.
Cowboy
posted July 31, 2003 08:36 PM
its located just to the left of the front bolt for the tank
posted August 01, 2003 06:54 AM
A word of caution-- DO NOT DO THIS WRONG -- you will blow the ECU. Use only the wires with red on them.
"An expert is one who has already committed all concievable errors"
Doug
Cowboy
posted August 01, 2003 07:46 AM
Thanks Doug,good thing i guessed right the 1st time
0.94012498855591 seconds processing time
