BIKELAND > FORUMS > ZX12R ZONE.com > Thread: bike is using oil - ideas? NEW TOPIC NEW POLL POST REPLY
jonwright
posted June 23, 2003 06:41 PM        Edited By: jonwright on 23 Jun 2003 19:45
Bike is using oil - ideas?
Recently I've done a reasonable amount of tweaks to my bike. So, I'm not sure which change correlated to my bike using oil. Presumably, none of them would - save the removal of the Kleen Air system.
BUT - My bike will use up about 1/8-1/4 of a quart over about 1k miles. Right about then I'll have to top it off. I have rather inspected the bike and there aren't any obvious leaks.
However, my bike backfires something awful on decel and my carbon pipe is getting discolored on the ends of the can. At the entrance and exit of the can the fibre is getting kinda brownish in color. Don't think a pic will show up. And the carbon deposits on the inside lip of the can is pretty thick. No obvious smoking that would indicate it's burning a bunch of oil.
I have a PC3 and I've loaded the Muzzy map for my Muzzy pipe (Oh, I Mean Daveindaytona's custom map - funny how they are the same, eh?). One wouldn't THINK my bike is running very rich, but it appears by the puff of smoke on throttle blip, backfiring, and carbon in the can it just might be running rich.
So, mods as of late include:
1. Removal of Kleen Air system
2. Installation of Muzzy full system
3. PC3
4. Muzzy manual timing advancer @4 degrees
5. 20w - 50 oil
That's about it.
I don't have block off plates over the ports on the heads - they are coming. But we put silicone in the holes and there doesn't appear to be obvious signs of oil blowing out of the ports - but I'm going to check.
One would assume the viscosity wouldn't matter in this instance. I also switched to the 20w50 after winter time, which is about when I started doing stuff to the bike as well.
Any ideas, fellas? Anyone else using that amount of oil?
LUCKY12
posted June 23, 2003 07:15 PM
Jon i would put it all back stock that should solve your oil problem you crazy bastard.
your car is slow
Fuck Nitrous...Got Boost?
posted June 23, 2003 07:23 PM        Edited By: your car is slow on 23 Jun 2003 20:23
What color is the smoke? White or black?
Are there any signs of oil leaking out of the head or the valve cover?
Does the bike appear to be down on power?
Put a harley badge on it somewhere?
Do not taunt happy fun ball!
RAC4IT
Bergie
posted June 23, 2003 07:48 PM
There's only one way to fix this problem; install a billet stroker crank, billet bigblock, forged pistons, big cams, port the head and lots of nitrous. After that you should be good to go as far as oil consumption goes
Oh wait that's just my solution to everything.
jonwright
posted June 23, 2003 07:49 PM
Allright you fuckers. Ain't going stock, and haven't lost any power. Smoke is rather black - oil is white, right?
Inspected outside of engine - no obvious leaks anywhere. Detailed search coming soon.
Lucky, you are the Powell Pud Puller.
YCIS - Harley badge? I said it wasn't leaking oil.....
jonwright
posted June 23, 2003 07:52 PM
So how did the nitrous do for the premature ejaculation? And the stroker crank? Didn't that make yer ass sore? But I'll bet the big cams were just right, weren't they?
ZHooligan
Post Whore Extraordinaire!
posted June 23, 2003 08:09 PM
Oil is gray, water (blown head gasket) is white fuel is usually black. Sometimes when your really rich fuel will contaminate the oil.
Check your airbox. I had a problem like this and found oil in the airbox coming from the crankcase vent. I solved it using Bergies suggestion and have not leaked a drop since.
future; -- Youth is forever.
jonwright
posted June 23, 2003 08:40 PM
Zdrool, tell me a bit more about what Bergie's suggestion is - wait a minute....is this an evil plot to get me to drag race????
your car is slow
posted June 23, 2003 08:42 PM        Edited By: your car is slow on 23 Jun 2003 21:43
ZHooligan
posted June 23, 2003 09:09 PM
Bored, stroked, balanced, built you name it, and NOS. zero oil consumption! Does burn an above normqal amount of race fuel though!
harryzx-12
posted June 24, 2003 05:37 AM
Add more oil ,you arkansas lawn burnout bitch!
your car is slow
posted June 24, 2003 06:43 AM
Ah..harry...yer such a problem solver
jonwright
posted June 24, 2003 07:32 AM
Oh, yeah. I guess I could just squeeze the oil I'll need out of yer oily pony tail you Florida Fudge Packer.
harryzx-12
posted June 24, 2003 09:21 AM
Instead why don't you squeeze some magic root oil out of me with your lips, jonjackoffright!
You wouldn't get much oil out of my hair (I wash it everyday)
jonwright
posted June 24, 2003 10:37 AM        Edited By: jonwright on 24 Jun 2003 11:38
Bwahahaha! Doesn't take much to get Harry all riled up, now, does it?
your car is slow
posted June 24, 2003 10:59 AM
haha...hes a big dumb animal isnt he?
DaveInDaytona
posted June 24, 2003 11:47 AM
Any oil in the airbox or the catch bottle ?
Sorry to ask a question relevant to the topic and not throw out a degrading comment.
DaytonaSportbikes Forum
ZHooligan
posted June 24, 2003 03:52 PM
Hey!! I asked that above! Is there an echo here?
slug
Out in search of my mind...
posted June 24, 2003 04:10 PM
yeh but people believe what dave says...
;P
(sorry gotta make up for the lack of degrading comment in floriduh boy's post)
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
aliveagain
posted June 24, 2003 06:09 PM
my first thought was the ring gaps were lining up.
TedG
posted June 24, 2003 07:29 PM        Edited By: TedG on 24 Jun 2003 20:31
That is not big oil consumption. If you ride around at high RPMs the oil will vaporize and get sucked up into the air box and through the motor. If I ride around normally, it uses almost nothing, when I dial it up for long periods and especially when it is hot it will use some oil . You might try to switch brands of oil if it really bugs you.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
ninja12
posted June 24, 2003 09:09 PM
Thanks Ted, He had me worried.
I can tell my oil level drops in the window after 500-1000 miles.
But that includes about 50 1/4 passes.
I just change the oil.
redelk
Please... speak to the hand.
posted June 24, 2003 09:39 PM
Ted, I can attest that he has had it SERIOUSLY wicked up ever since his last oil change. I MEAN SERIOUSLY!
A week at the Gap, chasing after Lucky and Ninjaman, then 700+ miles of more exit darkies, more high speed runs, shifter/peg scraping and complaining that the bike is now geared too low for the kind of top end speeds he's interested in.
If that won't vaporize a cc or two of oil, I don't know what will.
-Ernest Hemingway
jonwright
posted June 25, 2003 07:55 AM        Edited By: jonwright on 25 Jun 2003 08:56
Okay, okay. I'll quit worrying about it.
And yes, I have been running the dog shit out of the bike. Guess I'll just need to really keep an eye on the oil - not that I didn't before, but since I'm now keeping the RPM's stratospherically high I should expect it.
By the way, my little Zook doesn't do that and I run the shit out of it.
0.37173986434937 seconds processing time
