BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 ecu flashing NEW TOPIC NEW POLL POST REPLY
teamtaz
posted July 26, 2011 03:35 AM
zx12 ecu flashing
is there anyone in the uk that flashes zx12 ecu b1 model,been speaking with ridge racer about removing un-needed senors ie speed sensor, gear sensor and removing rev resirtictions but he seams to be very busy at moment,cheers
CLL72
posted August 08, 2011 10:16 AM
Hi teamtaz,
I am french and new on this forum.
I have a ZX12R model 2002 B1 (ECU: 21175-1091).
I would reflash my ecu to take out speed limiter and power limiter in 2 and 3 gear.
Do you know where I could find a free Prog16z.exe application?
Could you help me, please?
Let me know
Christophe
CLL72
harryzx-12
posted August 08, 2011 12:58 PM
I have a friend that is looking to purchase the software to adjust the zx-12 ecu. He already has one for hayabusas.Anybody know where he can get the software for ZX-12??
Thanks,
harry
tuusinii
posted August 08, 2011 11:01 PM
You can do the flashing without the expensive software. Psychegr wrote his own program that You can find for free. Here is all the files You need :http://www.bikeland.org/board/viewthread.php?FID=1&TID=23797&pagenumber=32. I've been using this summer for tuning with psychegr:s program and I'm now currently on my 15th map and it's starting to be quite close. Getting the full throttle right was easy, but when the engine is in speed density mode it takes a lot of driving to get it right... Still have to tune the middle TPS positions, but riding is now quite good and there isin't that big problems like there was when cruising... Also altered the ignition maps a little and removed the extra advance in 4000-5000 RPM zone. Also changed the RPM limit to 12000 just for extra reserve...
0.26177597045898 seconds processing time
