BIKELAND > FORUMS > ZX12R ZONE.com > Thread: need clutch help NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted August 06, 2011 06:13 PM
need clutch help
so i recently replaced everything clutch wise cause mine went ka-BOOM so got new basket and new clutch fibers and steels put it back together. when i went to take off it would make this noise allmost like it was slippin but isnt slippin. so i took apart checked everything out put back together and adjusted evertything by the book, when i put into first thebike jumps amd wants to go... ive tried adjusting every which way is there somwthing im missin
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
herbg26
posted August 07, 2011 01:41 AM
Double check the clutch height again, and re-adjust clutch...It is not completely disengaging
Herb
Kawasaki lover
Paul2281
posted August 07, 2011 05:09 AM
Everything is stuck together with oil....Hold the front break when you put it in gear....And double check adjustment as stated too....Sometimes you need to gto out and put a few miles on it to get it unstuck.....
zx12r2001
posted August 08, 2011 04:50 AM
check your puller angle. If its greater than 60 it wont fully disengage. I had the problem as well.
0.23058199882507 seconds processing time
