BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 NEW TOPIC NEW POLL POST REPLY
teamtaz
posted June 23, 2011 01:59 AM
zx12
does anyone know if on a zx12 b2 model ecu,you can get rid of some on the functions,ie speed sensor,gear postion sensor,starter lock out,cheers
tuusinii
posted June 26, 2011 10:17 PM
As the whole ECU code has been taken out of the ECU (look thread Hacking ZX12 ECU one ECU at time or something similar) that surely can be done, but it needs some coding and expertice and don't know if it has been done. I remember that RidgeRacer sometime talked about making the ECU read all the fuel and ignition numbers from the same table so You don't need to make corrections to all four cylinders... That topspeed limiter hack is allready done...
0.23484992980957 seconds processing time
