BIKELAND > FORUMS > ZX12R ZONE.com > Thread: speedo not working NEW TOPIC NEW POLL POST REPLY
suzukidude87
posted June 08, 2011 05:24 PM
speedo not working
hello all, just finished putting a 2002 ZX12 together, gages sweep when key is turned on, RPMs work but MPH dont, and the miles dont clock, could I have missed hooking up a wire or does it sound like the gage is bad?
thanks GOD for blessing us with bikes!
Michaels12
posted June 08, 2011 07:01 PM
I bet its the sensor in the engine ....look right behind the coolant resevoir. thats where you get the signal.
suzukidude87
posted June 09, 2011 02:40 AM
thanks will check that out........
suzukidude87
posted June 09, 2011 02:43 AM
RPMs are working, miles and MPH is not............
zx12mark
posted June 09, 2011 08:40 PM
do you have a speedo healer.if all the dip switches are not set to off the speedo won`t work
tuusinii
posted June 09, 2011 11:36 PM
As it's B-model ZX12 the speedo signal goes also to the ECU for speed restriction so if the sensor isn't working there would be an FI-light. If not there is break in the wire or gauge is broken. I'd first check the wire with multimeter for continuity.
Michaels12
posted June 10, 2011 02:26 AM
Good point Toni..but if the gauges both sweep at self test, then what.....
shiphteey
posted June 10, 2011 03:50 AM
If I were you I Wouldn't fix it...I'd wait till I got a speeding ticket, then go to a shop and get a work order or quote showing you had a defiective speedo....
Blammo....reduction in said charge on your court date.
A.
Gemini Motorcycles
tuusinii
posted June 10, 2011 04:41 AM
If the gauges sweep it tels that the stepper motor in the gauge is working and it's just waiting the signal. I'd first check the wires that they're not broken. If it shows continuity then check that there is voltage (multimeter in AC mode). If there is Then it's something inside the cluster. You can check the signal by raising Your rear wheel and putting it on gear. Then just measure that You have voltage at the gauge. If You don't have a service manual - get one...
suzukidude87
posted June 11, 2011 05:53 AM
thanks for the help guys.........when I get time I will let u guys know what I find........
0.21880102157593 seconds processing time
