BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Turning over, but not starting NEW TOPIC NEW POLL POST REPLY
maddfayce
SARR SGT@ARMS
posted September 28, 2009 06:07 PM
Here is the deal. 2000 ZX12R 12,xxx miles. I rode her for 200+ miles on Friday. I got home, burned the rear tire a smidget, and turned her off to raise the garagedoor. I jumped back on her and she turned over but did not start. I rolled her down the driveway and popped the clutch and she started right up. I let her run (afterwards I remembered she needs to run around 3000 rpm to recharge the battery) for 20 minutes and then shut her off. I tried to restart her immediately with turn over and no start. The next day she did the same but ended up doing nothing but clicking. I connected her to the truck with the negative on the rear brake pedal and positive to the nut on the side of the battery tray. Nothing. I have been checkin the juice in the battery and it stays between 11.41 and 11.72 volts. All fuses are intact. Not sure what else can be done or what the problem might be. I was told the rear pressure sensor is out, would that play a factor since it has been out since I got the bike in June at 4300 miles and she now has over 12k? I was also thinking would amps play a part in it startin even though she has enough volts?
posted September 28, 2009 08:54 PM
maddfayce,
yr battery ought to show 12.6-12.8V with motor off, 13.8-14.2-ish revving it.
rear pressure sensor not a factor, nope
sounds like it's time to see the battery man.
you have put 8k on it since june???
you've been rolling!
after you replace the battery, why not roll down to the Texas Mile Oct 16-18; yr profile says SA, just a hop,skip & jump to Goliad.
tshultz
posted September 29, 2009 01:35 PM
I think there is a 30amp fuse at the back of the battery tray see if that's blown.
maddfayce
SARR SGT@ARMS
posted September 29, 2009 08:27 PM
Fuse is good. Going with a Yuamah (spell check) battery. If I am not training soldiers that sounds great. I will check for posts on here and I can mapquest how to get there from here.
Texas12R
posted September 30, 2009 07:22 AM
Yuasa ytx-14b I think
Chango
posted September 30, 2009 07:07 PM
could it be the plugs? I know when my plugs fouled it was the same way. It ran once or twice before it refused to turn over.
woppi
posted October 01, 2009 02:56 AM
do you have a good / new battery ??
look at:
1.) all fuse“s !!
2.) switch -- the kickstand !
3.) switch --the clutch lever !
4.) switch -- stopswitch - right side handlebar !
5. look at the minus wire - which is fixed at the engine - near the clutch cover
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
woppi
posted October 01, 2009 02:57 AM
no -- plugs are not the problem !!
woppi
posted October 01, 2009 03:00 AM        Edited By: woppi on 1 Oct 2009 11:02
thake a look:
http://www.bikeland.org/board/viewthread.php?FID=1&TID=39399
woppi
maddfayce
SARR SGT@ARMS
posted October 02, 2009 10:13 AM
I stripped the bike and checked back there (regulator?) I say its the battery. New one be here today. I just changed the plugs, well two of them. I need to finish gettin the inner two done.
0.42200112342834 seconds processing time
