BIKELAND > FORUMS > ZX12R ZONE.com > Thread: MORE MONEY MORE PROBLEMS NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted July 16, 2009 05:38 PM
OK ABOUT TWO WEEKS AGO I CHANGED THE BATTERY OUT NOW I TRY TO START IT AND IT MAKES THIS SPUTTERING NOISE WTF IS THIS????
STARTING TO THINK I SHOULDA JUST GOT A DUCATI
  Ignore this member    Click here to visit BALTIMORE410's homepage.
whitehendrix
fails!
posted July 16, 2009 08:28 PM
definitely a loose connection or low voltage on the battery.
that click /buzz is a chatter produced by the contacts pulling in, making the crcuit, passing power to the starter, then the satarter pulling so much power the voltage drops below the "latch" point of the solenoid, and jhe magnetic field gets too weak to hold the contacts closed.. it drops out, opens the contacts, which instantly resorts power at the battery and as long as you're holding the button in, it'll act like a buzzer.
closely look at you ground wire at the frame, motor 9(r whereever it mounts to) the battery, and all the heavy wires running from the battery to the starter.
meter it and make sure theres 12V at the battery.
i bet it'll fire right up if ya jump start it..
if and when you do get it started, you should make approx 14-14.5V at about 4000-6000rpm.
if you're not, then you've got something loose, unplugged otr a charging system issue.
good luck man!! keep us posted..
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
Stuart Racing
N.H.R.A . Dragracing.
posted July 17, 2009 06:02 AM
Damn did they charge the battery up before the picked it up or did you?????Sounds like it`s dead....
BALTIMORE410
posted July 17, 2009 07:54 AM
imma test the battery today to see whats going on but if that battery is garbage imma take it right back to the dealership
BALTIMORE410
posted July 17, 2009 12:25 PM
I TOOK THE BATTERY FROM MY RED 2000 ZX12R AND SWAPPED IT OUT WITH THE BATTERY ON MY BIKE IN THE VIDEO.... IT FIRED RIGHT UP WTF AND I JUST HAD THE BATTERY CHANGED OUT 2 WEEKS AGO AT THE DEALERSHIP!!!!!!!!!!! im on my lunch break right now but the second i get off im going down to advance auto or auto zone and have the battery tested if that battery is junk im marching down to the dealership bright and early tomorrow morning with my receipt and demand an explanition the battery from the dealership cost me 75 bucks plus install fees yet the battery from my red bike i bought from auto zone for barely 30 dollars go figure????? bottom line... i smell bullshit!!!!
shiphteey
posted July 17, 2009 03:08 PM
Doesnt' make sense for a new battery to be dead in 2 weeks? Was it not properly charged to the point where it would go dead in 2 weeks? Does the battery still look new? Hope you get it squared away, at least test the battery.
Best of luck!
A.
Gemini Motorcycles
whitehendrix
fails!
posted July 17, 2009 07:42 PM
hopefully they treat ya good. most places won't.. especially on that. that's classified as a wear item like brakes and clutches.
good luck man!! at least it's an easy fix!! just it IS bullshit tho
Stuart Racing
posted July 18, 2009 06:24 AM
Sometimes they just hand to ya thinking it will have enough charge to start the bike and go riding will eventually charge it up....But since it sat for 2 weeks , it probably went dis charged.....I charge a new batter for at least 8 to 12 hours a slowly as possible 1 amp per hour....
jeremy_kokwk
posted July 19, 2009 03:56 PM
if your batt does not hold the charges after sitting around for 2 weeks, i guess like me , it is time to change the magneto coil and alternator, as for the batt you can keep it since you say you just change. i did all the changes just weeks ago, one time changing all 3 stuffs. should had done that 4 years back when the wiring to the alternator starts burning ..........
0.238933801651 seconds processing time
